주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Garmin DriveSmart 55 EX Motherboard Replacement
필요한 것
    1. Garmin DriveSmart 55 EX Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 Garmin DriveSmart 55 EX Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 Garmin DriveSmart 55 EX Motherboard Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
      • Use a T5 Torx screwdriver to remove the four 4.2 mm black screws from the back case.
      • Insert the plastic opening tool into the gap between the screen and case, and release the clips along the edges of the device.
      • Use opening picks along the perimeter to keep them separated until you can remove the screen.
      댓글 쓰기
    2. Garmin DriveSmart 55 EX Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Garmin DriveSmart 55 EX Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Garmin DriveSmart 55 EX Motherboard Replacement: 2 단계, 이미지 3개 중 3개
      • Gently separate the screen from the case and place the device flat on the surface.
      • Avoid pulling on the screen too forcefully, as the display ribbon cable is still connected to the motherboard.
      • Use a T5 Torx screwdriver to remove the four 3.8 mm silver screws from the motherboard.
      • Avoid scratching the motherboard when using the screwdriver, as this can damage the device.
      • Gently pry the motherboard up using the plastic opening tool.
      댓글 쓰기
    3. Garmin DriveSmart 55 EX Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Garmin DriveSmart 55 EX Motherboard Replacement: 3 단계, 이미지 2개 중 2개
      • Use your fingers or tweezers to disconnect the battery connector on the underside of the motherboard.
      • Avoid pulling on the cables.
      댓글 쓰기
    4. Garmin DriveSmart 55 EX Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Garmin DriveSmart 55 EX Motherboard Replacement: 4 단계, 이미지 2개 중 2개
      • Desolder the three solder points with a soldering iron to disconnect the wires from the motherboard.
      • Be careful when using the soldering iron, the tip is hot to the touch and can damage the motherboard or other surfaces when held or placed on them.
      댓글 쓰기
    5. Garmin DriveSmart 55 EX Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Garmin DriveSmart 55 EX Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Garmin DriveSmart 55 EX Motherboard Replacement: 5 단계, 이미지 3개 중 3개
      • Use a spudger or a clean fingernail to flip up the locking flap on the ZIF connector.
      • Use the widest tool possible to avoid damaging the delicate hinge pins.
      • Use tweezers to gently pull the gold ribbon cable from the socket on the motherboard.
      • Be careful when removing the ribbon cable because it is thin and can tear easily.
      • Remove the screen.
      댓글 쓰기
    6. Garmin DriveSmart 55 EX Motherboard Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the motherboard from the device.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Jacob Behnke
회원 가입일: 03/11/26
707 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 16
전체 시간: 111
