주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Garmin Nuvi 42LM Screen Replacement
필요한 것
    1. Garmin Nuvi 42LM Screen Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Garmin Nuvi 42LM Screen Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Garmin Nuvi 42LM Screen Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
      • Remove the four screws on the back of the GPS using the T5 Torx screwdriver.
      댓글 쓰기
    2. Garmin Nuvi 42LM Screen Replacement: 2 단계, 이미지 3개 중 1개 Garmin Nuvi 42LM Screen Replacement: 2 단계, 이미지 3개 중 2개 Garmin Nuvi 42LM Screen Replacement: 2 단계, 이미지 3개 중 3개
      • Pry the GPS open using a plastic opening tool.
      • When prying open the device, use caution to avoid damaging the motherboard.
      댓글 쓰기
    1. Garmin Nuvi 42LM Screen Replacement, Motherboard: 3 단계, 이미지 3개 중 1개 Garmin Nuvi 42LM Screen Replacement, Motherboard: 3 단계, 이미지 3개 중 2개 Garmin Nuvi 42LM Screen Replacement, Motherboard: 3 단계, 이미지 3개 중 3개
      • Using the T5 Torx screwdriver, remove the two screws located on the motherboard.
      • There are two screws - one in the back and one in the front.
      댓글 쓰기
    2. Garmin Nuvi 42LM Screen Replacement: 4 단계, 이미지 1개 중 1개
      • Move the motherboard from from its designated location on the GPS.
      • Do not pull on red, green, and black cables when repositioning the motherboard.
      댓글 쓰기
    3. Garmin Nuvi 42LM Screen Replacement: 5 단계, 이미지 2개 중 1개 Garmin Nuvi 42LM Screen Replacement: 5 단계, 이미지 2개 중 2개
      • Gently unplug the red, green, and black bundled cable to remove the battery.
      댓글 쓰기
    4. Garmin Nuvi 42LM Screen Replacement: 6 단계, 이미지 2개 중 1개 Garmin Nuvi 42LM Screen Replacement: 6 단계, 이미지 2개 중 2개
      • Use blue plastic opening tool to carefully pry the battery from the GPS.
      • You might need to use additional force when prying because there is adhesive glue on the back of the battery.
      댓글 쓰기
    5. Garmin Nuvi 42LM Screen Replacement: 7 단계, 이미지 1개 중 1개
      • Using a soldering iron, desolder the black and blue wires connected to the motherboard.
      • Once the black and blue wires are desoldered, llift the motherboard out and away from the device.
      • Check out this awesome guide on how to solder and desolder connections.
      댓글 쓰기
    1. Garmin Nuvi 42LM Screen Replacement, Screen: 8 단계, 이미지 2개 중 1개 Garmin Nuvi 42LM Screen Replacement, Screen: 8 단계, 이미지 2개 중 2개
      • Push out the screen by pulling back the black clips.
      • The screen is attached to the motherboard and needs to be replaced with it.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Elina Zhukov
회원 가입일: 01/18/17
558 평판
안내서 5개를 작성함
1가이드 댓글
Where do I purchase the screen for the Nuvi 42LM?
DR ROGER BROWNE - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 23
전체 시간: 731
