주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Garmin StreetPilot c320 Battery Replacement
필요한 것
    1. Garmin StreetPilot c320 Battery Replacement, Rear Case Assembly: 1 단계, 이미지 2개 중 1개 Garmin StreetPilot c320 Battery Replacement, Rear Case Assembly: 1 단계, 이미지 2개 중 2개
      • Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
      • Pry the outer frame off the perimeter of the rear panel assembly.
      • The cover will easily pop off.
      댓글 쓰기
    2. Garmin StreetPilot c320 Battery Replacement: 2 단계, 이미지 2개 중 1개 Garmin StreetPilot c320 Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
      • Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
      • Be extremely cautious when separating both halves, as the rear case assembly is still attached to the front case assembly via a few connectors.
      댓글 쓰기
    3. Garmin StreetPilot c320 Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Gently pull the battery cable connector from its socket on the motherboard.
      • The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
      댓글 쓰기
    1. Garmin StreetPilot c320 Battery Replacement, Battery: 4 단계, 이미지 1개 중 1개
      • Do not disconnect the black wire. Doing so may cause severe damage to your device.
      • Remove the two #00 Phillips screws securing the battery to the rear case assembly.
      댓글 쓰기
    2. Garmin StreetPilot c320 Battery Replacement: 5 단계, 이미지 2개 중 1개 Garmin StreetPilot c320 Battery Replacement: 5 단계, 이미지 2개 중 2개
      • Use a plastic opening tool to peel back the battery bracket.
      • Cautiously grasp the battery and lift it out of the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
8다른 기여자 명과 함께
Arturo Barajas
회원 가입일: 01/18/12
11 평판
안내서 3개를 작성함
Cal Poly, Team 11-19, Maness Winter 2012 Cal Poly, Team 11-19, Maness Winter 2012 회원
CPSU-MANESS-W12S11G19
4 회원들
안내서 8개를 작성함
2가이드 댓글
Where can I purchase a new Garmin StreetPilot c320 Battery Replacement battery?
john Lyons
11 Cavanaugh Cres
Terrace Bay Ontario
P0T2W0 Canada
John Lyons - 답글 공유
Thanks' - I just found two of my old Garmin StreetPilot c320 units in storage.
This will be the project of the evening watching movies.
New 18650 Battery with charging protection is ready.
Thankfully these are ten times easier than the TomTom just completed with new battery install.
Cheers
Philscbx - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 25
전체 시간: 2,890
