주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Garmin Vívoactive 4 Button Replacement
필요한 것
    1. Garmin Vívoactive 4 Button Replacement, Watch Band: 1 단계, 이미지 1개 중 1개
      • Flip the watch on its back to reveal the watch band connection pins.
      댓글 쓰기
    2. Garmin Vívoactive 4 Button Replacement, Remove Bands: 2 단계, 이미지 3개 중 1개 Garmin Vívoactive 4 Button Replacement, Remove Bands: 2 단계, 이미지 3개 중 2개 Garmin Vívoactive 4 Button Replacement, Remove Bands: 2 단계, 이미지 3개 중 3개
      • Wedge your fingernail or the tip of a spudger underneath the watch band's small metal pin.
      • Push on the pin to release the strap from it's hinge.
      • Pull the strap away from the watch to disconnect it.
      • The strap will not pull away if the pin isn't fully pushed in.
      댓글 쓰기
    3. Garmin Vívoactive 4 Button Replacement: 3 단계, 이미지 1개 중 1개
      • With both straps removed, a new replacement watch band may be inserted.
      댓글 쓰기
    1. Garmin Vívoactive 4 Button Replacement, Screen: 4 단계, 이미지 1개 중 1개
      • Use a heatgun to loosen the adhesive beneath the screen, it should take a 5-10 minutes for adhesive to loosen.
      • Handle the watch with care to avoid burning yourself after it has been heated. Review the How to Use a Heat Gun to Soften Adhesive guide.
      댓글 쓰기
    2. Garmin Vívoactive 4 Button Replacement: 5 단계, 이미지 2개 중 1개 Garmin Vívoactive 4 Button Replacement: 5 단계, 이미지 2개 중 2개
      • Wedge a thin opening tool or your iFixit Jimmy in between the seam where the screen and the watch’s housing connect.
      • Pry the screen off the device.
      • There is a cable underneath the screen that needs to be disconnected - be careful not to rip it.
      • Work quickly so the adhesive doesn’t cool too much.
      댓글 쓰기
    3. Garmin Vívoactive 4 Button Replacement: 6 단계, 이미지 3개 중 1개 Garmin Vívoactive 4 Button Replacement: 6 단계, 이미지 3개 중 2개 Garmin Vívoactive 4 Button Replacement: 6 단계, 이미지 3개 중 3개
      • Carefully disconnect both cables from the motherboard by placing the tip of your spudger under the edge of the connector, and prying the connector straight up from its socket.
      댓글 쓰기
    4. Garmin Vívoactive 4 Button Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the screen.
      댓글 쓰기
    1. Garmin Vívoactive 4 Button Replacement, Motherboard: 8 단계, 이미지 1개 중 1개
      • Carefully peel off the ribbon tape that is holding down the motherboard.
      댓글 쓰기
    2. Garmin Vívoactive 4 Button Replacement: 9 단계, 이미지 1개 중 1개
      • Place the tip of your spudger under the edge of the connector, and pry the connector straight up from its socket to disconnect the battery from the motherboard.
      • Do this carefully to avoid ripping the cable.
      댓글 쓰기
    3. Garmin Vívoactive 4 Button Replacement: 10 단계, 이미지 3개 중 1개 Garmin Vívoactive 4 Button Replacement: 10 단계, 이미지 3개 중 2개 Garmin Vívoactive 4 Button Replacement: 10 단계, 이미지 3개 중 3개
      • Use a Phillips #00 screwdriver to remove the 3.2 mm screw on the motherboard.
      • Use a Phillips #00 screwdriver to remove the 4.8 mm screw on the motherboard.
      댓글 쓰기
    4. Garmin Vívoactive 4 Button Replacement: 11 단계, 이미지 3개 중 1개 Garmin Vívoactive 4 Button Replacement: 11 단계, 이미지 3개 중 2개 Garmin Vívoactive 4 Button Replacement: 11 단계, 이미지 3개 중 3개
      • Pull the battery cable up to dislodge the motherboard.
      • Gently remove the motherboard from the socket.
      • The motherboard may get caught under the housing due to the clips on the edge.
      댓글 쓰기
    1. Garmin Vívoactive 4 Button Replacement, Battery: 12 단계, 이미지 2개 중 1개 Garmin Vívoactive 4 Button Replacement, Battery: 12 단계, 이미지 2개 중 2개
      • Use the pointed tip of a spudger to carefully push on each side of the battery connector to disconnect the battery from the motherboard.
      댓글 쓰기
    2. Garmin Vívoactive 4 Button Replacement: 13 단계, 이미지 3개 중 1개 Garmin Vívoactive 4 Button Replacement: 13 단계, 이미지 3개 중 2개 Garmin Vívoactive 4 Button Replacement: 13 단계, 이미지 3개 중 3개
      • Use a spudger to pry the battery from the case.
      • Be careful not to damage any surrounding components.
      • There is an adhesive holding the battery down. Use an iOpener if it is too difficult to remove the battery with the spudger alone.
      댓글 쓰기
    1. Garmin Vívoactive 4 Button Replacement, Button: 14 단계, 이미지 3개 중 1개 Garmin Vívoactive 4 Button Replacement, Button: 14 단계, 이미지 3개 중 2개 Garmin Vívoactive 4 Button Replacement, Button: 14 단계, 이미지 3개 중 3개
      • Wedge a spudger or your iFixit Jimmy in between the button's snap ring and the watch housing.
      • Carefully pry the snap ring off the button.
      • Remove the button and components from the watch housing.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Bryan Chavez
회원 가입일: 11/01/23
380 평판
안내서 4개를 작성함
UMass Dartmouth, Team 1-3, Petersen Fall 2023 UMass Dartmouth, Team 1-3, Petersen Fall 2023 회원
UMASSD-PETERSEN-F23S1G3
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 28
전체 시간: 1,069
