주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Garmin Vívoactive 4 Screen Replacement
필요한 것
    1. Garmin Vívoactive 4 Screen Replacement, Watch Band: 1 단계, 이미지 1개 중 1개
      • Flip the watch on its back to reveal the watch band connection pins.
      댓글 쓰기
    2. Garmin Vívoactive 4 Screen Replacement, Remove Bands: 2 단계, 이미지 3개 중 1개 Garmin Vívoactive 4 Screen Replacement, Remove Bands: 2 단계, 이미지 3개 중 2개 Garmin Vívoactive 4 Screen Replacement, Remove Bands: 2 단계, 이미지 3개 중 3개
      • Wedge your fingernail or the tip of a spudger underneath the watch band's small metal pin.
      • Push on the pin to release the strap from it's hinge.
      • Pull the strap away from the watch to disconnect it.
      • The strap will not pull away if the pin isn't fully pushed in.
      댓글 쓰기
    3. Garmin Vívoactive 4 Screen Replacement: 3 단계, 이미지 1개 중 1개
      • With both straps removed, a new replacement watch band may be inserted.
      댓글 쓰기
    1. Garmin Vívoactive 4 Screen Replacement, Screen: 4 단계, 이미지 1개 중 1개
      • Use a heatgun to loosen the adhesive beneath the screen, it should take a 5-10 minutes for adhesive to loosen.
      • Handle the watch with care to avoid burning yourself after it has been heated. Review the How to Use a Heat Gun to Soften Adhesive guide.
      댓글 쓰기
    2. Garmin Vívoactive 4 Screen Replacement: 5 단계, 이미지 2개 중 1개 Garmin Vívoactive 4 Screen Replacement: 5 단계, 이미지 2개 중 2개
      • Wedge a thin opening tool or your iFixit Jimmy in between the seam where the screen and the watch’s housing connect.
      • Pry the screen off the device.
      • There is a cable underneath the screen that needs to be disconnected - be careful not to rip it.
      • Work quickly so the adhesive doesn’t cool too much.
      댓글 쓰기
    3. Garmin Vívoactive 4 Screen Replacement: 6 단계, 이미지 3개 중 1개 Garmin Vívoactive 4 Screen Replacement: 6 단계, 이미지 3개 중 2개 Garmin Vívoactive 4 Screen Replacement: 6 단계, 이미지 3개 중 3개
      • Carefully disconnect both cables from the motherboard by placing the tip of your spudger under the edge of the connector, and prying the connector straight up from its socket.
      댓글 쓰기
    4. Garmin Vívoactive 4 Screen Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the screen.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jacob Byron
회원 가입일: 11/01/23
223 평판
안내서 2개를 작성함
UMass Dartmouth, Team 1-3, Petersen Fall 2023 UMass Dartmouth, Team 1-3, Petersen Fall 2023 회원
UMASSD-PETERSEN-F23S1G3
4 회원들
안내서 28개를 작성함
3가이드 댓글
Will this affect the waterproofing of the device?
Interested Repairer - 답글 공유
I originally had this watch not responding to touch (it was gradual, parts of the screen started not working bit by bit). Finally the whole screen did not respond to touch inputs. Suspected the entire screen assembly had to be replaced but this shockingly proved unsuccessful. What else would kill this capability of the watch? I don't understand!
Shaun Tam - 답글 공유
wait, I got the screen to work after a hard restart. Quite interesting, it must be learning/recalibrating the inputs each time it starts, like a scale.
My watch now crashes and turns off whenever I try to start an activity (I tried the run activity) and when trying to do NFC payments. The screen was the only thing I played with. What could cause this? I remember hearing from someone that the bezel acts as an antenna of sorts.
Shaun Tam - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 44
지난 30일: 213
전체 시간: 6,495
