주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Garmin Vivoactive Motherboard Replacement
필요한 것
    1. Garmin Vivoactive Motherboard Replacement, Wristband: 1 단계, 이미지 1개 중 1개
      • Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
      • Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
      • While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
      댓글 쓰기
    2. Garmin Vivoactive Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Garmin Vivoactive Motherboard Replacement: 2 단계, 이미지 2개 중 2개
      • Once the 1mm screw is removed, reinsert the metal screwdriver in that same hole.
      • Gently push the strap's pin out. It will begin to protrude from the other end.
      • Use your fingers to grab the exposed pin and slide it free. The strap should now be disconnected from the device.
      댓글 쓰기
    1. Garmin Vivoactive Motherboard Replacement, Display Unit: 3 단계, 이미지 1개 중 1개
      • Place a heated iOpener over the display to loosen the adhesive.
      • After about a minute, the iOpener may be removed.
      • For more in depth instructions on using the iOpener, refer to the iOpener guide.
      댓글 쓰기
    2. Garmin Vivoactive Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Garmin Vivoactive Motherboard Replacement: 4 단계, 이미지 2개 중 2개
      • Place the blue plastic opening tool in-between the screen and plastic casing of the watch and slowly pry up one side of the screen.
      댓글 쓰기
    3. Garmin Vivoactive Motherboard Replacement: 5 단계, 이미지 1개 중 1개
      • Once the first side has come free, wedge the blue pick in between the screen and watch unit on that side.
      • Complete one pass around the perimeter of the screen to break the adhesive bond on all four sides.
      • Insert it a minimal distance to avoid damaging internal components.
      댓글 쓰기
    4. Garmin Vivoactive Motherboard Replacement: 6 단계, 이미지 1개 중 1개
      • Use the blue plastic opening tool to pry up the side of the glass. Raise it to a point where your fingernail can fit in the gap.
      • Do the same on the opposite side of the device until you have a good grip of the screen.
      댓글 쓰기
    5. Garmin Vivoactive Motherboard Replacement: 7 단계, 이미지 1개 중 1개
      • Obtain a careful grip of the screen from two of its sides.
      • Slowly lift the screen off of the case. Separate it just enough so as not to damage the connection to the motherboard.
      댓글 쓰기
    6. Garmin Vivoactive Motherboard Replacement: 8 단계, 이미지 1개 중 1개
      • Detach the orange tab that connects the screen to the motherboard with a gentle uplift using a plastic opening tool.
      • Upon completing this step, the screen should be free from the rest of the device.
      댓글 쓰기
    1. Garmin Vivoactive Motherboard Replacement, Battery: 9 단계, 이미지 2개 중 1개 Garmin Vivoactive Motherboard Replacement, Battery: 9 단계, 이미지 2개 중 2개
      • Follow previous guides until you've exposed the battery as shown.
      • Begin by removing the battery connector tab.
      • Be sure not to use a metal implement or your fingers to remove this tab. Doing so may cause personal harm or damage to the electrical components.
      댓글 쓰기
    2. Garmin Vivoactive Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Garmin Vivoactive Motherboard Replacement: 10 단계, 이미지 2개 중 2개
      • Use a plastic opening pick to gently pry out the battery as shown.
      • The battery is Lithium Polymer, follow safe handling procedures and DO NOT deform it upon removal.
      댓글 쓰기
    3. Garmin Vivoactive Motherboard Replacement: 11 단계, 이미지 3개 중 1개 Garmin Vivoactive Motherboard Replacement: 11 단계, 이미지 3개 중 2개 Garmin Vivoactive Motherboard Replacement: 11 단계, 이미지 3개 중 3개
      • With the battery loose from the case, rotate it to expose the attached tab
      • Gently pry up the attached tab with a fingernail.
      • Keep the vibrator, circled in red, as you may need to solder it to the new battery upon re-installation later.
      댓글 쓰기
    1. Garmin Vivoactive Motherboard Replacement, Motherboard: 12 단계, 이미지 2개 중 1개 Garmin Vivoactive Motherboard Replacement, Motherboard: 12 단계, 이미지 2개 중 2개
      • Remove the four 2.4 mm screws with a PH00 Phillips head screwdriver.
      • Make an effort not to damage any nearby components of the motherboard with the screwdriver.
      댓글 쓰기
    2. Garmin Vivoactive Motherboard Replacement: 13 단계, 이미지 2개 중 1개 Garmin Vivoactive Motherboard Replacement: 13 단계, 이미지 2개 중 2개
      • Use the spudger to pry up the board from the case.
      • Insert the spudger a minimum distance beneath the board as there are components below.
      • Wiggle the exposed side of the board from each end until it comes free.
      • Use proper electrostatic discharge safety when removing and handling the board.
      댓글 쓰기
    3. Garmin Vivoactive Motherboard Replacement: 14 단계, 이미지 2개 중 1개 Garmin Vivoactive Motherboard Replacement: 14 단계, 이미지 2개 중 2개
      • Remove the GPS antenna by sliding it away from the board.
      • Keep track of the antenna and add it to the new board upon replacement.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Tessa Gunnin
회원 가입일: 10/01/15
466 평판
안내서 2개를 작성함
Cal Poly, Team 1-21, Maness Fall 2015 Cal Poly, Team 1-21, Maness Fall 2015 회원
CPSU-MANESS-F15S1G21
4 회원들
안내서 17개를 작성함
2가이드 댓글
Any tips on where to buy a motherboard?
Breener - 답글 공유
Only <3 months, the motherboard is gone?
Do you have any service shop where I can mail for repairing? I am not going to mail order a motherboard and install by myself every 3 months.
Ming
Yong-Ming Yu - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 43
전체 시간: 15,056
