주요 콘텐츠로 건너뛰기
Gateway KAV60 LT2016U Hard Drive Replacement
Lydia Benjock
Lydia Benjock8 다른 기여자
최종 수정일 January 28, 2019
5 - 10 분
쉬움
더 나은 이미지가 필요함
With a Phillips #0 screwdriver, the hard drive can easily be replaced.
필요한 것
도구
  1. Gateway KAV60 LT2016U Hard Drive Replacement, Battery: 1 단계, 이미지 3개 중 1개 Gateway KAV60 LT2016U Hard Drive Replacement, Battery: 1 단계, 이미지 3개 중 2개 Gateway KAV60 LT2016U Hard Drive Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Unlock the tab located in the top left corner of the netbook.
    • The red tab indicated that the battery has been properly unlocked.
    • Remove the battery.
    • When working with electronics, it is always wise to remove the power source before taking the device apart.
  2. Gateway KAV60 LT2016U Hard Drive Replacement, Hard Drive: 2 단계, 이미지 1개 중 1개
    • The hard drive is located under this cover.
  3. Gateway KAV60 LT2016U Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 Gateway KAV60 LT2016U Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the two (2) 5mm screws holding the cover down using the Phillips #0 screwdriver.
  4. Gateway KAV60 LT2016U Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 Gateway KAV60 LT2016U Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to lift the cover.
  5. Gateway KAV60 LT2016U Hard Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Using a Phillips #0 screwdriver, remove a third 5mm screw that holds the second cover that is directly protecting the hard drive.
  6. Gateway KAV60 LT2016U Hard Drive Replacement: 6 단계, 이미지 3개 중 1개 Gateway KAV60 LT2016U Hard Drive Replacement: 6 단계, 이미지 3개 중 2개 Gateway KAV60 LT2016U Hard Drive Replacement: 6 단계, 이미지 3개 중 3개
    • Slide the silver cover up; the hole on the cover and the hole for the screw will no longer match up.
    • Lift the silver cover; this will expose the hard drive.
결론
작성자
8다른 기여자 명과 함께
Lydia Benjock
회원 가입일: 10/18/13
1,216 평판
안내서 10개를 작성함
Clemson, Team 14-3, Benson Fall 2013 Clemson, Team 14-3, Benson Fall 2013 회원
CLEM-BENSON-F13S14G3
3 회원들
안내서 22개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 1,697
