주요 콘텐츠로 건너뛰기
Gateway M-2626u Hard Drive Replacement
Femi
Femi3 다른 기여자
최종 수정일 June 22, 2019
5 - 10 분
쉬움
The replacement of the hard drive may be necessary if you experience crashes frequently or if there is data loss and file corruption. You can also upgrade the hard drive if you would like to have access to more storage or faster laptop in general, either way, try out this simple guide!
필요한 것
도구
  1. Gateway M-2626u Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • To prevent injury, make sure the laptop is not plugged in while removing the battery!
    • Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
  2. Gateway M-2626u Hard Drive Replacement: 2 단계, 이미지 3개 중 1개 Gateway M-2626u Hard Drive Replacement: 2 단계, 이미지 3개 중 2개 Gateway M-2626u Hard Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Push the switch to the right, toward the inside of the computer to dislodge the battery.
    • Finally, pull the battery outwards and away from the laptop as depicted in this image.
  3. Gateway M-2626u Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2개 중 1개 Gateway M-2626u Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2개 중 2개
    • Using the Phillips #1 screwdriver, remove the three 6mm screws holding the hard drive panel in place.
  4. Gateway M-2626u Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, pry open the plastic panel covering the hard drive.
  5. Gateway M-2626u Hard Drive Replacement: 5 단계, 이미지 3개 중 1개 Gateway M-2626u Hard Drive Replacement: 5 단계, 이미지 3개 중 2개 Gateway M-2626u Hard Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Using your hands, carefully pull out the hard drive from its compartment.
결론
작성자
3다른 기여자 명과 함께
Femi
회원 가입일: 04/06/18
219 평판
안내서 2개를 작성함
UMass Dartmouth, Team S3-G7, Peak Fall 2018 UMass Dartmouth, Team S3-G7, Peak Fall 2018 회원
UMASSD-PEAK-F18S3G7
3 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 259
