주요 콘텐츠로 건너뛰기
Gateway MA7 Fan Replacement
필요한 것
  1. Gateway MA7 Fan Replacement, Fan: 1 단계, 이미지 1/1
    • Before starting this replacement, make sure the device is powered off and the battery is removed.
    • This particular device is missing the battery.
    • To remove your battery, slide the plastic tabs on the back of the laptop and pull the battery out of the device.
  2. Gateway MA7 Fan Replacement: 2 단계, 이미지 1/3 Gateway MA7 Fan Replacement: 2 단계, 이미지 2/3 Gateway MA7 Fan Replacement: 2 단계, 이미지 3/3
    • Remove the seven 6mm screws from the back panel with a Phillips #0 screwdriver.
  3. Gateway MA7 Fan Replacement: 3 단계, 이미지 1/3 Gateway MA7 Fan Replacement: 3 단계, 이미지 2/3 Gateway MA7 Fan Replacement: 3 단계, 이미지 3/3
    • Pull upwards on the top of the plastic panel to remove it.
    • With the exception of the screw marked "K", all of the screws will remain connected to the plastic piece.
  4. Gateway MA7 Fan Replacement: 4 단계, 이미지 1/2 Gateway MA7 Fan Replacement: 4 단계, 이미지 2/2
    • Remove the five 6 mm screws with a Phillips #0 screw driver to detach the fan and cooling unit from the motherboard.
    • The four screws on the silver metal bands of the fan will not come off of the actual component.
  5. Gateway MA7 Fan Replacement: 5 단계, 이미지 1/3 Gateway MA7 Fan Replacement: 5 단계, 이미지 2/3 Gateway MA7 Fan Replacement: 5 단계, 이미지 3/3
    • Lifting from the left side of the fan, start to pull the fan off of the motherboard.
    • Be sure not to pull the fan all the way off the motherboard yet. Before it can be completely removed the cables must be disconnected.
    • There may be thermal paste adhering the fan to the motherboard. Be sure to lift the fan slowly and gently.
  6. Gateway MA7 Fan Replacement: 6 단계, 이미지 1/3 Gateway MA7 Fan Replacement: 6 단계, 이미지 2/3 Gateway MA7 Fan Replacement: 6 단계, 이미지 3/3
    • In order to properly remove the fan, disconnect the cable that is attached to the motherboard.
    • Gently grasp the connecting cable from under the fan and pull it out of the socket on the motherboard to disconnect it.
  7. Gateway MA7 Fan Replacement: 7 단계, 이미지 1/3 Gateway MA7 Fan Replacement: 7 단계, 이미지 2/3 Gateway MA7 Fan Replacement: 7 단계, 이미지 3/3
    • With the screws removed and the cable disconnected, just lift the fan off the motherboard to remove it.
    • When you replace the fan, be sure to reapply thermal paste here.
결론
Cameron Sheedy
회원 가입일: 03/05/18
145 평판
안내서 1개 작성함
UMass Dartmouth, Team S6-G2, Bernier Spring 2018 UMass Dartmouth, Team S6-G2, Bernier Spring 2018 회원
UMASSD-BERNIER-S18S6G2
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 14
전체 시간: 466
