주요 콘텐츠로 건너뛰기
Gateway NE52203u USB Port Replacement
Stephen Spees
Stephen Spees2 다른 기여자
최종 수정일 May 18, 2020
10 분
조정
So your laptop won't download data when you plug in a USB device? The problem is most likely a non-functioning USB port, and you'll have to replace it. This guide will provide you with the steps you need in order to replace your old USB port with a new one.
필요한 것
도구
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Gateway NE52203u USB Port Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Flip the device over onto its backside in order to access the battery.
  2. Gateway NE52203u USB Port Replacement: 2 단계, 이미지 2개 중 1개 Gateway NE52203u USB Port Replacement: 2 단계, 이미지 2개 중 2개
    • Locate the battery release latch and slide it over to the other side.
    • A small tool like a pen or screwdriver may be helpful in sliding the latch to release the battery.
  3. Gateway NE52203u USB Port Replacement: 3 단계, 이미지 1개 중 1개
    • Grab the newly ejected battery from the device to completely remove it.
    • When reinserting the new battery, make sure the prongs on the battery are aligned with the corresponding holes on the laptop.
  4. Gateway NE52203u USB Port Replacement, Touchpad Assembly: 4 단계, 이미지 2개 중 1개 Gateway NE52203u USB Port Replacement, Touchpad Assembly: 4 단계, 이미지 2개 중 2개
    • Remove 18 6.0 mm Phillips #00 screws from the bottom of the laptop.
    • Remove 5 6.0 mm Phillip #00 screws from under cover.
  5. Gateway NE52203u USB Port Replacement: 5 단계, 이미지 1개 중 1개
    • Remove three 2.9 mm Phillips #00 screws from the battery compartment.
  6. Gateway NE52203u USB Port Replacement: 6 단계, 이미지 2개 중 1개 Gateway NE52203u USB Port Replacement: 6 단계, 이미지 2개 중 2개
    • Separate the bottom panel from the touchpad assembly by inserting a plastic opening tool between them on all four sides.
  7. Gateway NE52203u USB Port Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Pull black ribbon wire from port using tweezers in order to completely separate touchpad assembly from bottom assembly.
  8. Gateway NE52203u USB Port Replacement: 8 단계, 이미지 3개 중 1개 Gateway NE52203u USB Port Replacement: 8 단계, 이미지 3개 중 2개 Gateway NE52203u USB Port Replacement: 8 단계, 이미지 3개 중 3개
    • Disconnect the two ZIF ports that attach the touchpad assembly to the motherboard.
    • First flip open the flap covering the ribbon using a spudger or fingernail.
    • Second gently pull the ribbon away from the port.
  9. Gateway NE52203u USB Port Replacement, USB Port: 9 단계, 이미지 2개 중 1개 Gateway NE52203u USB Port Replacement, USB Port: 9 단계, 이미지 2개 중 2개
    • Using a spudger, pry the ZIF connector upwards.
  10. Gateway NE52203u USB Port Replacement: 10 단계, 이미지 1개 중 1개
    • Use your fingers to gently disconnect the ribbon wire from the USB circuit board.
  11. Gateway NE52203u USB Port Replacement: 11 단계, 이미지 1개 중 1개
    • Using a #00 Phillips head screwdriver, remove the 2.9 mm screw on the USB circuit board.
  12. Gateway NE52203u USB Port Replacement: 12 단계, 이미지 1개 중 1개
    • Finally, remove the old USB port.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Stephen Spees
회원 가입일: 03/20/15
542 평판
안내서 4개를 작성함
Baylor, Team 2-1, Grigsby Spring 2015 Baylor, Team 2-1, Grigsby Spring 2015 회원
BU-GRIGSBY-S15S2G1
4 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 686
