주요 콘텐츠로 건너뛰기
Gateway NE56R27u Hard Drive Replacement
Piper Moeller
Piper Moeller3 다른 기여자
최종 수정일 July 19, 2020
5 분
쉬움
The hard drive is how you store data in your device. If you have experienced a hardware failure or you simply want to upgrade your Gateway NE56R27u’s hard drive, this guide will allow you to replace your laptop’s hard drive. Upgrading your hard drive can allow your device to run with increased speed and capacity and with more space to store files.
필요한 것
도구
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
  1. Gateway NE56R27u Hard Drive Replacement, Battery: 1 단계, 이미지 2개 중 1개 Gateway NE56R27u Hard Drive Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Using the spudger, push the orange tab to the unlock position.
  2. Gateway NE56R27u Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 Gateway NE56R27u Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the battery from its compartment.
    • When reinstalling, insert back end of battery first, then clicking into place.
  3. Gateway NE56R27u Hard Drive Replacement, Hard Drive: 3 단계, 이미지 3개 중 1개 Gateway NE56R27u Hard Drive Replacement, Hard Drive: 3 단계, 이미지 3개 중 2개 Gateway NE56R27u Hard Drive Replacement, Hard Drive: 3 단계, 이미지 3개 중 3개
    • Unscrew the two 7.9mm Phillips #0 screws that secure the service cover.
  4. Gateway NE56R27u Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 Gateway NE56R27u Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Use the opening tool to gently pry open the compartment covering.
  5. Gateway NE56R27u Hard Drive Replacement: 5 단계, 이미지 3개 중 1개 Gateway NE56R27u Hard Drive Replacement: 5 단계, 이미지 3개 중 2개 Gateway NE56R27u Hard Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Unscrew the two 0.5mm screws from the hard drive brackets using the Phillips #0 screwdriver.
    • Pull the plastic tab attached to the hard drive to the right to remove the hard drive.
    • The hard drive plugs into the port on the left within the compartment. Be sure to gently remove the hard drive without damaging the port.
  6. Gateway NE56R27u Hard Drive Replacement: 6 단계, 이미지 2개 중 1개 Gateway NE56R27u Hard Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the hard drive by lifting up the right side, releasing the hard drive from the compartment clips on the left.
결론
작성자
3다른 기여자 명과 함께
Piper Moeller
회원 가입일: 01/24/20
619 평판
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 2
전체 시간: 301
