주요 콘텐츠로 건너뛰기
Gateway Solo 1200 Fan Replacement
Riki
Riki4 다른 기여자
최종 수정일 October 17, 2020
45 분 - 1 시간
어려움
Follow this replacement guide to replace a faulty keyboard and damaged frame.
Your Gateway Solo 1200’s fan is an integral part of the cooling system. If your laptop feels unusually warm or powers off suddenly, the fan might not be providing enough cool air to the system. Without a clean or working fan, your laptop can overheat and cause permanent damage to the internal components.
필요한 것
도구
  1. Gateway Solo 1200 Fan Replacement, Battery: 1 단계, 이미지 3개 중 1개 Gateway Solo 1200 Fan Replacement, Battery: 1 단계, 이미지 3개 중 2개 Gateway Solo 1200 Fan Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Turn off your laptop and disconnect it from AC Adapter before use.
    • Locate the battery latch on the bottom of the laptop.
    • Release the latch by pressing it with your thumb and sliding it to the right.
    • Slide the battery out of its compartment.
    • Discharge your laptop by pushing the power button after removing the battery.
  2. Gateway Solo 1200 Fan Replacement, Keyboard and Frame: 2 단계, 이미지 2개 중 1개 Gateway Solo 1200 Fan Replacement, Keyboard and Frame: 2 단계, 이미지 2개 중 2개
    • Turn the device so the back is facing you.
    • Unscrew the 2 mm screws with a Phillips #0 screwdriver.
    • Unscrewing these back screws partially releases the keyboard.
  3. Gateway Solo 1200 Fan Replacement: 3 단계, 이미지 2개 중 1개 Gateway Solo 1200 Fan Replacement: 3 단계, 이미지 2개 중 2개
    • Open up the device so the keyboard is visible.
    • Locate the front panel with the power button above the keyboard.
    • Remove the panel by gently pulling on it.
    • The panel should pop out with little force.
  4. Gateway Solo 1200 Fan Replacement: 4 단계, 이미지 3개 중 1개 Gateway Solo 1200 Fan Replacement: 4 단계, 이미지 3개 중 2개 Gateway Solo 1200 Fan Replacement: 4 단계, 이미지 3개 중 3개
    • Gently lift the keyboard panel up.
    • Flip the keyboard panel over to reveal the underside.
    • Gently tug on the ribbon cable at the bottom of the keyboard panel to release the keyboard.
  5. Gateway Solo 1200 Fan Replacement: 5 단계, 이미지 3개 중 1개 Gateway Solo 1200 Fan Replacement: 5 단계, 이미지 3개 중 2개 Gateway Solo 1200 Fan Replacement: 5 단계, 이미지 3개 중 3개
    • Remove both monitor hinge covers at the base of the screen by unscrewing the 2 mm screws with a Phillips #0 screwdriver.
    • Locate the visual output cord on the exposed left hinge connecting the monitor to the laptop.
    • Gently tug on the visual output cord to remove the screen.
  6. Gateway Solo 1200 Fan Replacement: 6 단계, 이미지 3개 중 1개 Gateway Solo 1200 Fan Replacement: 6 단계, 이미지 3개 중 2개 Gateway Solo 1200 Fan Replacement: 6 단계, 이미지 3개 중 3개
    • Once the screen is removed, locate the keyboard frame screws.
    • Unscrew the outer frame and gently pull it away from the device.
    • Gently tug on the trackpad connector underneath the keyboard frame to completely remove it.
  7. Gateway Solo 1200 Fan Replacement, Fan: 7 단계, 이미지 3개 중 1개 Gateway Solo 1200 Fan Replacement, Fan: 7 단계, 이미지 3개 중 2개 Gateway Solo 1200 Fan Replacement, Fan: 7 단계, 이미지 3개 중 3개
    • Locate the heatsink next to the fan.
    • Unscrew the four 2mm screws attaching the heatsink to the device.
    • Lift the heatsink upwards, careful not to disturb other internal components.
  8. Gateway Solo 1200 Fan Replacement: 8 단계, 이미지 3개 중 1개 Gateway Solo 1200 Fan Replacement: 8 단계, 이미지 3개 중 2개 Gateway Solo 1200 Fan Replacement: 8 단계, 이미지 3개 중 3개
    • Unscrew the four screws attaching the fan to the device.
    • Carefully tug the fan's connector from the heat system.
    • The connector is fragile and shouldn't be yanked to avoid damages.
결론
작성자
4다른 기여자 명과 함께
Riki
회원 가입일: 08/26/19
235 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 23
전체 시간: 259
