주요 콘텐츠로 건너뛰기
Ghost Longboard Wheel Replacement
Patricia Roux
Patricia Roux2 다른 기여자
최종 수정일 April 1, 2022
10 - 20 분
쉬움
Use this guide to replace the damaged, warped, or dented wheels on your Ghost Longboard. This guide requires minimal skill and no prior experience. It is especially useful if your board is not as fast as it used to be, it has become more difficult to turn, or it does not coast for as long as you would like it to. the ghost longboard wheels are easy to replace.
  1. Ghost Longboard Wheel Replacement, Wheel: 1 단계, 이미지 1개 중 1개
    • Using a 15 mm socket wrench, unscrew the axle nut.
  2. Ghost Longboard Wheel Replacement: 2 단계, 이미지 1개 중 1개
    • Using your fingers, remove the axle nut from the axle.
  3. Ghost Longboard Wheel Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the washer from the axle.
  4. Ghost Longboard Wheel Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the wheel from the axle.
  5. Ghost Longboard Wheel Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the second washer from the axle.
  6. Ghost Longboard Wheel Replacement: 6 단계, 이미지 1개 중 1개
    • Slide a new washer onto the axle.
  7. Ghost Longboard Wheel Replacement: 7 단계, 이미지 2개 중 1개 Ghost Longboard Wheel Replacement: 7 단계, 이미지 2개 중 2개
    • Place the new wheel on the axle.
    • Be sure to position the flat side of the wheel so it is facing inward.
  8. Ghost Longboard Wheel Replacement: 8 단계, 이미지 1개 중 1개
    • Place a second washer on the axle exterior to the wheel.
  9. Ghost Longboard Wheel Replacement: 9 단계, 이미지 1개 중 1개
    • Place an axle nut on the axle.
  10. Ghost Longboard Wheel Replacement: 10 단계, 이미지 1개 중 1개
    • Using a 15 mm socket wrench, tighten the axle nut.
    • Be sure to tighten the axle nut enough to prevent the wheel from wobbling, but not so tight as to prohibit the wheel from spinning freely.
결론
Repeat these steps on the three remaining wheels.
작성자
2다른 기여자 명과 함께
Patricia Roux
회원 가입일: 03/18/21
184 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 386
