주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google Pixel 3 Back Cover Adhesive Installation
필요한 것
  1. Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: 1 단계, 이미지 3개 중 1개 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: 1 단계, 이미지 3개 중 2개 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: 1 단계, 이미지 3개 중 3개
    • Pick and scrape away the old adhesive from the frame.
    • Use a spudger to scrape away any lingering adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the frame.
    • For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
    댓글 쓰기
  2. Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: 2 단계, 이미지 3개 중 1개 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: 2 단계, 이미지 3개 중 2개 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: 2 단계, 이미지 3개 중 3개
    • Repeat the previous step for the back cover adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the back cover coating.
    • Don't use isopropyl alcohol near the rear camera bracket as it will damage its adhesive and foam.
    댓글 쓰기
  3. Google Pixel 3 Back Cover Adhesive Installation, Prepare the replacement adhesive: 3 단계, 이미지 1개 중 1개
    • Peel away the clear plastic lining to expose the frame side of the replacement adhesive.
    댓글 쓰기
  4. Google Pixel 3 Back Cover Adhesive Installation, Apply the adhesive: 4 단계, 이미지 2개 중 1개 Google Pixel 3 Back Cover Adhesive Installation, Apply the adhesive: 4 단계, 이미지 2개 중 2개
    • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Lower the adhesive onto the frame.
    • Use the rear camera and corners to properly align the adhesive.
    댓글 쓰기
  5. Google Pixel 3 Back Cover Adhesive Installation, Secure the adhesive to the frame: 5 단계, 이미지 2개 중 1개 Google Pixel 3 Back Cover Adhesive Installation, Secure the adhesive to the frame: 5 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger or your fingernail to press down on the adhesive.
    • Slide along the perimeter to secure the adhesive to the frame.
    댓글 쓰기
  6. Google Pixel 3 Back Cover Adhesive Installation, Peel away the outer plastic lining: 6 단계, 이미지 2개 중 1개 Google Pixel 3 Back Cover Adhesive Installation, Peel away the outer plastic lining: 6 단계, 이미지 2개 중 2개
    • Peel away the blue outer plastic lining on the back cover side of the adhesive.
    댓글 쓰기
  7. Google Pixel 3 Back Cover Adhesive Installation, Connect the fingerprint sensor cable: 7 단계, 이미지 2개 중 1개 Google Pixel 3 Back Cover Adhesive Installation, Connect the fingerprint sensor cable: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers or your fingers to position the fingerprint sensor cable over its connector on the motherboard.
    • Use the flat end of a spudger or your finger to press down on the connector to secure it to the motherboard.
    댓글 쓰기
  8. Google Pixel 3 Back Cover Adhesive Installation: 8 단계, 이미지 3개 중 1개 Google Pixel 3 Back Cover Adhesive Installation: 8 단계, 이미지 3개 중 2개 Google Pixel 3 Back Cover Adhesive Installation: 8 단계, 이미지 3개 중 3개
    • Use tweezers or your fingers to place the bracket over the fingerprint sensor cable.
    댓글 쓰기
  9. Google Pixel 3 Back Cover Adhesive Installation: 9 단계, 이미지 2개 중 1개 Google Pixel 3 Back Cover Adhesive Installation: 9 단계, 이미지 2개 중 2개
    • Use a Phillips PH00 screwdriver to install the two 4.1 mm screws securing the bracket to the frame.
    댓글 쓰기
  10. Google Pixel 3 Back Cover Adhesive Installation, Peel away the remaining plastic lining: 10 단계, 이미지 2개 중 1개 Google Pixel 3 Back Cover Adhesive Installation, Peel away the remaining plastic lining: 10 단계, 이미지 2개 중 2개
    • Peel away the red plastic lining to expose the back cover side of the adhesive.
    댓글 쓰기
  11. Google Pixel 3 Back Cover Adhesive Installation, Secure the back cover to the frame: 11 단계, 이미지 2개 중 1개 Google Pixel 3 Back Cover Adhesive Installation, Secure the back cover to the frame: 11 단계, 이미지 2개 중 2개
    • Lower the back cover onto the frame.
    • Press down on all edges of the back cover to secure it to the frame.
    • To help the adhesive bond more securely, heat the perimeter of the back cover and then place the phone face-down under a heavy stack of books for 30 minutes.
    댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 3 Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Chayton Ritter
회원 가입일: 08/21/20
26,975 평판
안내서 105개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 25
지난 30일: 82
전체 시간: 4,602
