주요 콘텐츠로 건너뛰기
Google Pixel 3 Rear-Facing Camera Replacement
필요한 것
  1. Google Pixel 3 Rear-Facing Camera Replacement, Weaken the back cover's adhesive: 1 단계, 이미지 1개 중 1개
  2. Google Pixel 3 Rear-Facing Camera Replacement, Create a gap in the seam: 2 단계, 이미지 3개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement, Create a gap in the seam: 2 단계, 이미지 3개 중 2개 Google Pixel 3 Rear-Facing Camera Replacement, Create a gap in the seam: 2 단계, 이미지 3개 중 3개
    • Apply a suction cup to the heated bottom edge of the back cover.
    • Make sure you did not mistake the screen side for the back cover side.
    • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere.
    • Lift on the suction cup with strong, steady force to create a gap.
    • Depending on how aged your phone is, this may take significant force. If you are having trouble, apply more heat and try again.
    • Insert an opening pick into the gap.
    • Don't use metal tools to pry, or you'll mar or shatter the glass back cover. If the panel won't budge, apply more heat, either with a hair dryer or heat gun.
  3. Google Pixel 3 Rear-Facing Camera Replacement, Fingerprint cable information: 3 단계, 이미지 1개 중 1개
    • When inserting an opening pick above the power button, be careful not to insert the pick too deeply, or you will damage the fingerprint sensor cable.
  4. Google Pixel 3 Rear-Facing Camera Replacement, Cut through the adhesive: 4 단계, 이미지 3개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement, Cut through the adhesive: 4 단계, 이미지 3개 중 2개 Google Pixel 3 Rear-Facing Camera Replacement, Cut through the adhesive: 4 단계, 이미지 3개 중 3개
    • Slice the adhesive along the bottom edge of the phone and around the right corner.
    • Leave a pick in the bottom edge to prevent the adhesive from re-sealing.
  5. Google Pixel 3 Rear-Facing Camera Replacement: 5 단계, 이미지 3개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement: 5 단계, 이미지 3개 중 2개 Google Pixel 3 Rear-Facing Camera Replacement: 5 단계, 이미지 3개 중 3개
    • Heat the right edge with an iOpener and continue slicing the adhesive with an opening pick.
    • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
  6. Google Pixel 3 Rear-Facing Camera Replacement: 6 단계, 이미지 3개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement: 6 단계, 이미지 3개 중 2개 Google Pixel 3 Rear-Facing Camera Replacement: 6 단계, 이미지 3개 중 3개
    • Continue heating and slicing through the rest of the phone perimeter. Leave a pick in each edge to prevent the adhesive from resealing.
    • When slicing above the power button, do not insert the pick more than halfway in to avoid damaging the fingerprint sensor cable.
  7. Google Pixel 3 Rear-Facing Camera Replacement, Lift the left edge of the back cover: 7 단계, 이미지 3개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement, Lift the left edge of the back cover: 7 단계, 이미지 3개 중 2개 Google Pixel 3 Rear-Facing Camera Replacement, Lift the left edge of the back cover: 7 단계, 이미지 3개 중 3개
    • Once you have sliced around the perimeter of the phone, carefully lift the left edge of the back cover.
    • Do not attempt to remove the back cover. It is still attached to the phone by the fingerprint sensor cable.
    • Flip the back cover along its long axis and rest it so that the fingerprint sensor cable is not strained.
  8. Google Pixel 3 Rear-Facing Camera Replacement, Remove the screws: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Remove the two 4.1 mm-long Phillips screws securing the fingerprint connector bracket.
    • During reassembly, be careful not to over-tighten these screws, or you may damage your display.
  9. Google Pixel 3 Rear-Facing Camera Replacement, Remove the fingerprint connector bracket: 9 단계, 이미지 3개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement, Remove the fingerprint connector bracket: 9 단계, 이미지 3개 중 2개 Google Pixel 3 Rear-Facing Camera Replacement, Remove the fingerprint connector bracket: 9 단계, 이미지 3개 중 3개
    • Use the point of a spudger to slide the fingerprint connector bracket out from under the NFC coil.
    • Remove the fingerprint connector bracket.
  10. Google Pixel 3 Rear-Facing Camera Replacement, Disconnect the fingerprint connector: 10 단계, 이미지 2개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement, Disconnect the fingerprint connector: 10 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the fingerprint connector from its socket.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  11. Google Pixel 3 Rear-Facing Camera Replacement, Remove the back cover: 11 단계, 이미지 3개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement, Remove the back cover: 11 단계, 이미지 3개 중 2개 Google Pixel 3 Rear-Facing Camera Replacement, Remove the back cover: 11 단계, 이미지 3개 중 3개
    • Remove the back cover.
    • Before you install a replacement back cover, be sure to remove all adhesive residue from the phone frame. Use an opening tool to scrape and high concentration isopropyl alcohol to clean the surface.
    • If you are re-using the back cover, be sure to clean off any adhesive, and apply new back cover adhesive.
    • If you are installing a replacement back cover, be sure to compare it with the original part. Transfer any remaining parts (such as the flash diffuser) over to your replacement part.
    • Follow this guide to correctly apply new back cover adhesive.
  12. Google Pixel 3 Rear-Facing Camera Replacement, Remove the screws: 12 단계, 이미지 1개 중 1개
    • Remove the five Phillips screws securing the wireless charging coil:
    • Two 1.9 mm screws
    • Two 4.2 mm screws
    • One 4.3 mm screw
  13. Google Pixel 3 Rear-Facing Camera Replacement, Remove the charging coil: 13 단계, 이미지 1개 중 1개
    • Lift up and remove the wireless charging coil.
  14. Google Pixel 3 Rear-Facing Camera Replacement, Disconnect the battery cable: 14 단계, 이미지 2개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement, Disconnect the battery cable: 14 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the battery press connector from its socket near the right edge of the phone.
  15. Google Pixel 3 Rear-Facing Camera Replacement, Remove the screws: 15 단계, 이미지 2개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement, Remove the screws: 15 단계, 이미지 2개 중 2개
    • Remove the two screws securing the camera bracket:
    • One 4.1 mm Phillips screw
    • One 4 mm standoff screw
    • Standoff screws are best removed using a standoff bit. In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    • Remove the camera bracket.
  16. Google Pixel 3 Rear-Facing Camera Replacement, Identify the cameras: 16 단계, 이미지 1개 중 1개
    • If you are replacing front-facing cameras, determine which one you need to replace:
    • Normal view camera
    • Wide-angle camera
    • If you are doing the motherboard removal procedure, you will need to remove both cameras.
  17. Google Pixel 3 Rear-Facing Camera Replacement, Disconnect the camera(s): 17 단계, 이미지 3개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement, Disconnect the camera(s): 17 단계, 이미지 3개 중 2개 Google Pixel 3 Rear-Facing Camera Replacement, Disconnect the camera(s): 17 단계, 이미지 3개 중 3개
    • Use the point of a spudger to pry up and disconnect the connector for the camera(s) you are replacing.
  18. Google Pixel 3 Rear-Facing Camera Replacement, Loosen the camera(s): 18 단계, 이미지 2개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement, Loosen the camera(s): 18 단계, 이미지 2개 중 2개
    • The cameras are held in place with adhesive.
    • Insert the point of a spudger behind the edge of the camera module and pry up to loosen it from the frame.
  19. Google Pixel 3 Rear-Facing Camera Replacement, Remove the camera(s): 19 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
    • Use a pair of blunt nose tweezers to remove the camera(s).
    • If the adhesive holding the camera module is in good condition, you can re-use the adhesive. Otherwise, replace the adhesive with double-sided Tesa tape.
    • When installing a replacement camera module, make sure that the phone frame lens are free of adhesive residue or debris.
  20. Google Pixel 3 Rear-Facing Camera Replacement, Disconnect the loudspeaker: 20 단계, 이미지 2개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement, Disconnect the loudspeaker: 20 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the loudspeaker connector from its motherboard socket near the right edge of the phone.
    • Be careful not to puncture the battery with the spudger.
  21. Google Pixel 3 Rear-Facing Camera Replacement, Remove the screws: 21 단계, 이미지 3개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement, Remove the screws: 21 단계, 이미지 3개 중 2개 Google Pixel 3 Rear-Facing Camera Replacement, Remove the screws: 21 단계, 이미지 3개 중 3개
    • Remove the following four Phillips screws:
    • One 1.9 mm screw
    • One 4.3 mm screw
    • Two 4.3 mm screws with thinner shanks
    • Remove the tiny grounding clip from the left screw hole. Be careful not to lose it.
    • The grounding clip installs such that the contoured edge faces the left side of the phone.
    • Remove the small plastic insert from the right side of the USB-C port.
    • Be sure to reinstall this insert before you screw down the daughterboard.
  22. Google Pixel 3 Rear-Facing Camera Replacement, Loosen the loudspeaker: 22 단계, 이미지 2개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement, Loosen the loudspeaker: 22 단계, 이미지 2개 중 2개
    • The loudspeaker is still held in place by a strong adhesive gasket. Before attempting to remove it, pry it up in a few different places to break the adhesive seal.
    • Insert the point of a spudger under the bottom right corner of the loudspeaker.
    • Pry up to loosen the loudspeaker from the phone.
  23. Google Pixel 3 Rear-Facing Camera Replacement: 23 단계, 이미지 2개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement: 23 단계, 이미지 2개 중 2개
    • Insert the point of a spudger under the top left corner of the loudspeaker.
    • Pry up to loosen the loudspeaker.
  24. Google Pixel 3 Rear-Facing Camera Replacement: 24 단계, 이미지 2개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement: 24 단계, 이미지 2개 중 2개
    • Insert the flat end of the spudger under the top edge of the loudspeaker, towards the left edge.
  25. Google Pixel 3 Rear-Facing Camera Replacement, Remove the loudspeaker: 25 단계, 이미지 2개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement, Remove the loudspeaker: 25 단계, 이미지 2개 중 2개
    • Remove the loudspeaker.
    • Before you install a replacement loudspeaker, check the adhesive gasket.
    • If it is in good condition, you can re-use the gasket. Make sure that the gasket does not cover the exit hole.
    • If the gasket is pulled out of place, remove it and replace the adhesive with a pre-cut strip or Tesa tape.
  26. Google Pixel 3 Rear-Facing Camera Replacement, Disconnect the charging assembly: 26 단계, 이미지 2개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement, Disconnect the charging assembly: 26 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the charging assembly's connector from its motherboard socket, near the right edge of the phone.
  27. Google Pixel 3 Rear-Facing Camera Replacement, Peel away the black tape: 27 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to carefully pry up the black tape holding the display flex cable in place, near the right edge of the phone.
    • Do not use metal tools to pry, or you may damage the flex cable.
  28. Google Pixel 3 Rear-Facing Camera Replacement, Disconnect the press connectors: 28 단계, 이미지 2개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement, Disconnect the press connectors: 28 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the following seven press-fit connectors from their motherboard sockets:
    • External buttons connector
    • Top microphone connector
    • Earpiece connector
    • Left squeeze sensor connector
    • Screen connector
    • Right squeeze sensor connector
    • SIM tray connector
  29. Google Pixel 3 Rear-Facing Camera Replacement, Move the earpiece speaker cable away from the motherboard: 29 단계, 이미지 1개 중 1개
    • Use the flat of a spudger to carefully bend the earpiece speaker's flex cable upwards, out of the way of the motherboard.
  30. Google Pixel 3 Rear-Facing Camera Replacement, Remove the screws: 30 단계, 이미지 3개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement, Remove the screws: 30 단계, 이미지 3개 중 2개 Google Pixel 3 Rear-Facing Camera Replacement, Remove the screws: 30 단계, 이미지 3개 중 3개
    • Some of these screws hold very small grounding clips in place. Be careful not to lose these clips as you remove the screws.
    • Remove the six screws securing the motherboard in place:
    • One 4.2 mm Phillips screw
    • Three 1.9 mm Phillips screws
    • One 4.3 mm Phillips screw
    • One 3.83 mm standoff screw
    • Remove and retain the three small metal grounding clips.
  31. Google Pixel 3 Rear-Facing Camera Replacement, Remove the antenna bracket: 31 단계, 이미지 3개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement, Remove the antenna bracket: 31 단계, 이미지 3개 중 2개 Google Pixel 3 Rear-Facing Camera Replacement, Remove the antenna bracket: 31 단계, 이미지 3개 중 3개
    • Carefully remove the antenna bracket from the top left edge of the phone.
    • To reinstall the small metal grounding clips:
    • Orient the clips such that the silver side is facing upwards.
    • The teardrop shaped clips should have their points facing towards the phone edge.
    • The double-holed clip dips downwards towards the frame's top-right screw hole.
  32. Google Pixel 3 Rear-Facing Camera Replacement, Check the motherboard: 32 단계, 이미지 2개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement, Check the motherboard: 32 단계, 이미지 2개 중 2개
    • Insert the point of a spudger near the top left corner of the motherboard, right below the rear-facing camera.
    • Pry up gently to loosen the motherboard, bending all flex cables away to accommodate for the movement.
    • If the motherboard feels firmly seated, check for any still-connected flex cables or screws.
  33. Google Pixel 3 Rear-Facing Camera Replacement, Loosen the motherboard: 33 단계, 이미지 2개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement, Loosen the motherboard: 33 단계, 이미지 2개 중 2개
    • Insert the spudger underneath the top edge of the motherboard and carefully pry up to loosen the motherboard.
    • The earpiece speaker's flex cable will press tightly against the motherboard. Take your time and carefully guide the motherboard around the flex cable.
  34. Google Pixel 3 Rear-Facing Camera Replacement, Remove the motherboard: 34 단계, 이미지 3개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement, Remove the motherboard: 34 단계, 이미지 3개 중 2개 Google Pixel 3 Rear-Facing Camera Replacement, Remove the motherboard: 34 단계, 이미지 3개 중 3개
    • Lift the left edge of the motherboard and carefully swing upwards towards the right. Carefully push any press connectors snagging the motherboard out of the way.
    • Do not attempt to fully remove the motherboard. It is still attached to the frame with some antenna cables.
    • When you reinstall the motherboard, be careful not to trap any flex cable connectors underneath it.
  35. Google Pixel 3 Rear-Facing Camera Replacement, Remove the rear-facing camera: 35 단계, 이미지 3개 중 1개 Google Pixel 3 Rear-Facing Camera Replacement, Remove the rear-facing camera: 35 단계, 이미지 3개 중 2개 Google Pixel 3 Rear-Facing Camera Replacement, Remove the rear-facing camera: 35 단계, 이미지 3개 중 3개
    • Use the point of a spudger to pry up and disconnect the rear-facing camera connector from its motherboard socket.
    • Lift the camera module away from the motherboard, peeling the adhesive in the process.
    • Remove the rear-facing camera.
결론
Repair didn’t go as planned? Check out our Google Pixel 3 Answers community for troubleshooting help.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
310,235 평판
안내서 701개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,648개를 작성함
4가이드 댓글
Pixel 3 and pixel 3xl rear cameras are same. If I buy pixel 3 camera and can I use this on pixel 3xl?
Suren - 답글
Time is not correct for this job. Only the disassembly itself takes 90 - 120 minutes. But assembly is a separate type of torture. Only to separate the old adhesive tape is very hard. For the instructions thank you, with bolts during assembly helped, but I do not recommend to disassemble it on your own. In my case, a professional replaced the camera for about 5 hours until I took my phone back.
Ruslan Dorokhin - 답글
It is possible to remove the rear camera without dismantling upper or lower speaker. The main PCB is sufficiently flexible. However, take care of the speaker connections while moving the PCB.
Most difficult step is the initial opening of the the back cover of the phone. I broke it (as it is made of glas), though being really carefully using dental floss to “cut” the glue. All other steps are not particular challenging.
Thanks for the ifxit guideline!
Frank Zoellner - 답글
I noticed pixel 3 cameras have different model numbers. Must the model number for the old camera be the same with the replacement?
lanre emmanuel - 답글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 1,483
지난 30일: 3,191
전체 시간: 21,821
