소개
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to remove or replace the loudspeaker module on your Google Pixel 4.
The loudspeaker is sealed against the frame with an adhesive gasket. If you remove the loudspeaker, the Pixel will no longer retain its water resistance.
Caution: Google warns that disassembly of the front laser assembly could result in hazardous exposure to invisible infrared laser emissions. Read their safety warnings here.
필요한 것
Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the left edge of the phone.
Press firmly to eject the tray.
Remove the SIM card tray.
Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
Insert the point of an opening pick into the gap.
Slide the opening pick across the bottom towards the left corner to slice the adhesive.
With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
Prepare an iOpener and apply it on the left edge of the phone for one minute.
Prepare an iOpener and apply it on the right edge of the phone for one minute.
Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
Do not try to pull the panel all the way off yet, as it is still connected to the phone.
Remove the five T3 Torx screws securing the battery connector shield:
Four 4.0 mm screws
One 2.1 mm screw
Use a T3 Torx driver to remove the two 4 mm screws securing the back panel connector cover.
Remove the two T3 Torx screws securing the loudspeaker:
One 4.2 mm screw
One 4.4 mm shouldered screw
Use a pair of tweezers to remove the loudspeaker, pivoting it up and out of the phone.
If it is in good condition, you can re-use the gasket. Make sure that the gasket does not cover the exit hole.
If the gasket is pulled out of place, remove it and replace the adhesive with a pre-cut strip or Tesa tape.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 3개
I have had customer with his pixel 4 loud speaker not working so i replaced it with other one which did not work for 30 second after installation but suddenly started working, its been 2 week’s and customer is back with same issue, no sound in loud speaker, it look like a board issue, Would be happy if someone can put sone light on it.
Its not a settings issue and resetting does not resolve it.
I do also have the same issue with bottom speaker of Pixel 4. It works and stops working periodically and it seems not speaker issue and even software reset doesn't help...
Where can i buy the loudspeaker?
