주요 콘텐츠로 건너뛰기
Google Pixel 4 Side Buttons Replacement
필요한 것
  1. Google Pixel 4 Side Buttons Replacement, Remove the SIM card tray: 1 단계, 이미지 1/3 Google Pixel 4 Side Buttons Replacement, Remove the SIM card tray: 1 단계, 이미지 2/3 Google Pixel 4 Side Buttons Replacement, Remove the SIM card tray: 1 단계, 이미지 3/3
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the left edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
  2. Google Pixel 4 Side Buttons Replacement, Heat the back panel glass: 2 단계, 이미지 1/1
    • Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Google Pixel 4 Side Buttons Replacement, Apply a suction cup: 3 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement, Apply a suction cup: 3 단계, 이미지 2/2
    • Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
  4. Google Pixel 4 Side Buttons Replacement, Insert an opening pick: 4 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement, Insert an opening pick: 4 단계, 이미지 2/2
    • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  5. Google Pixel 4 Side Buttons Replacement, Begin to slice the adhesive: 5 단계, 이미지 1/3 Google Pixel 4 Side Buttons Replacement, Begin to slice the adhesive: 5 단계, 이미지 2/3 Google Pixel 4 Side Buttons Replacement, Begin to slice the adhesive: 5 단계, 이미지 3/3
    • Slide the opening pick across the bottom towards the left corner to slice the adhesive.
    • With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  6. Google Pixel 4 Side Buttons Replacement, Slice the lefthand-side adhesive: 6 단계, 이미지 1/1
    • Prepare an iOpener and apply it on the left edge of the phone for one minute.
  7. Google Pixel 4 Side Buttons Replacement: 7 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement: 7 단계, 이미지 2/2
    • Insert a second opening pick underneath the back panel directly over the charge port.
    • Slide the opening pick to the bottom left corner of the phone.
  8. Google Pixel 4 Side Buttons Replacement: 8 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement: 8 단계, 이미지 2/2
    • Slide the opening pick around the bottom left corner and across the left side of the phone to slice the adhesive.
    • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
    • Stop when you reach the top left corner, near the camera, and leave the pick inserted.
  9. Google Pixel 4 Side Buttons Replacement, Slice righthand-side adhesive: 9 단계, 이미지 1/1
    • Prepare an iOpener and apply it on the right edge of the phone for one minute.
  10. Google Pixel 4 Side Buttons Replacement: 10 단계, 이미지 1/3 Google Pixel 4 Side Buttons Replacement: 10 단계, 이미지 2/3 Google Pixel 4 Side Buttons Replacement: 10 단계, 이미지 3/3
    • With the first two opening picks still in place, insert a third pick on the lower part of the righthand side.
    • Slide the opening pick up towards the top of the phone, slicing the right side's adhesive.
    • Stop when you reach the top right corner, and leave the pick inserted.
  11. Google Pixel 4 Side Buttons Replacement, Slice the top-side adhesive: 11 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement, Slice the top-side adhesive: 11 단계, 이미지 2/2
    • Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
  12. Google Pixel 4 Side Buttons Replacement, Lift up the back panel: 12 단계, 이미지 1/3 Google Pixel 4 Side Buttons Replacement, Lift up the back panel: 12 단계, 이미지 2/3 Google Pixel 4 Side Buttons Replacement, Lift up the back panel: 12 단계, 이미지 3/3
    • Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
    • Do not try to pull the panel all the way off yet, as it is still connected to the phone.
  13. Google Pixel 4 Side Buttons Replacement: 13 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement: 13 단계, 이미지 2/2
    • Continue swinging open the back panel until you can rest it on the left edge the phone, being careful not to put any stress on the attached ribbon cable.
    • During reassembly, this is a good point to power on your phone and test all functions before re-sealing the back panel. Be sure to power your phone back down completely before you continue working.
  14. Google Pixel 4 Side Buttons Replacement, Disconnect the battery: 14 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Remove the five T3 Torx screws securing the battery connector shield:
    • Four 4.0 mm screws
    • One 2.1 mm screw
  15. Google Pixel 4 Side Buttons Replacement: 15 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement: 15 단계, 이미지 2/2
    • Use a pair of tweezers to remove the battery connector shield.
  16. Google Pixel 4 Side Buttons Replacement: 16 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement: 16 단계, 이미지 2/2
    • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
    • Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  17. Google Pixel 4 Side Buttons Replacement: 17 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement: 17 단계, 이미지 2/2
    • Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs.
  18. Google Pixel 4 Side Buttons Replacement, Disconnect the back panel connector: 18 단계, 이미지 1/1
    • Use a T3 Torx driver to remove the two 4 mm screws securing the back panel connector cover.
  19. Google Pixel 4 Side Buttons Replacement: 19 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement: 19 단계, 이미지 2/2
    • Use a pair of tweezers to remove the back panel connector cover.
  20. Google Pixel 4 Side Buttons Replacement: 20 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement: 20 단계, 이미지 2/2
    • Using the pointed end of a spudger, pry up and disconnect the back panel connector.
  21. Google Pixel 4 Side Buttons Replacement, Remove the back panel: 21 단계, 이미지 1/1
    • Remove the back panel.
    • During reassembly, follow this guide to install custom-cut adhesives for your device.
    • Follow this guide if you are using a pre-cut adhesive card.
  22. Google Pixel 4 Side Buttons Replacement, Remove the adhesive strips: 22 단계, 이미지 1/3 Google Pixel 4 Side Buttons Replacement, Remove the adhesive strips: 22 단계, 이미지 2/3 Google Pixel 4 Side Buttons Replacement, Remove the adhesive strips: 22 단계, 이미지 3/3
    • Pull on the yellow pull tab of the adhesive strip with steady force.
    • If the adhesive becomes hard to pull, you can roll it around a spudger and continue pulling.
    • Continue firmly pulling up on the adhesive strip with constant force. If you're using a spudger, spin it every so often to keep the exposed section of the pull tab as short as possible.
    • This may take a lot of force.
    • These adhesive pull tabs are very prone to snapping in half during this process. Pull as slowly as possible.
    • If the adhesive pull tabs are not stretching, fill a plastic dropper or syringe with high concentration (>90%) isopropyl alcohol and apply a few drops under the left edge of the battery. Give the alcohol a minute to weaken the battery adhesive.
    • Continue this process for each of the three pull tabs, until all are either out or have snapped in half.
  23. Google Pixel 4 Side Buttons Replacement, Remove the battery: 23 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement, Remove the battery: 23 단계, 이미지 2/2
    • If the battery tabs snapped during removal, insert an opening pick on the upper right edge of the battery, slicing the adhesive underneath.
    • Even if you successfully removed all three adhesive pull tabs, using an opening pick to dislodge the battery may be helpful.
    • Don't insert the opening pick on or anywhere below the grip sensor cable, as the pick can damage the charge port flex cable located underneath the battery.
  24. Google Pixel 4 Side Buttons Replacement: 24 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement: 24 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
    구매
    • Do not reuse the battery if it has been deformed or damaged, as doing so is a potential safety hazard. Replace it with a new battery.
    • Lift the battery up and away from the phone to remove it. You may need to peel the battery away from any leftover adhesive tabs.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off with a lint-free cloth or allow it to air dry before installing your battery.
    • To install a replacement battery:
    • If you're using stretch release adhesive, apply them onto the battery. Otherwise, apply some double-sided tape, or pre-cut adhesive strips in the phone's battery well, being careful not to cover the charge port flex cable. Peel away any tape liners to expose the adhesive.
    • Temporarily re-connect the battery's connector to the motherboard socket. This ensures that the battery is properly positioned.
    • Lay the battery in place and press firmly.
    • Disconnect the battery connector from its motherboard socket and resume re-assembly.
  25. Google Pixel 4 Side Buttons Replacement, Remove the screws securing the camera connector cover: 25 단계, 이미지 1/1
    • Use a T3 Torx driver to remove the four 4 mm screws securing the camera connector cover.
  26. Google Pixel 4 Side Buttons Replacement: 26 단계, 이미지 1/3 Google Pixel 4 Side Buttons Replacement: 26 단계, 이미지 2/3 Google Pixel 4 Side Buttons Replacement: 26 단계, 이미지 3/3
    • Using a pair of tweezers, tilt the camera cover up and slide it out of the retaining slot on the upper right corner of the phone to remove.
  27. Google Pixel 4 Side Buttons Replacement, Disconnect the camera and sensor connectors: 27 단계, 이미지 1/3 Google Pixel 4 Side Buttons Replacement, Disconnect the camera and sensor connectors: 27 단계, 이미지 2/3 Google Pixel 4 Side Buttons Replacement, Disconnect the camera and sensor connectors: 27 단계, 이미지 3/3
    • Using the pointed end of a spudger, pry the camera and sensor connectors straight up from the motherboard.
  28. Google Pixel 4 Side Buttons Replacement: 28 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement: 28 단계, 이미지 2/2
    • Disconnect the additional sensor connector.
  29. Google Pixel 4 Side Buttons Replacement, Remove the front-facing camera and sensor assembly: 29 단계, 이미지 1/1
    • Use a T3 Torx driver to remove the two 2.4 mm screws securing the front camera and sensor assembly.
  30. Google Pixel 4 Side Buttons Replacement: 30 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement: 30 단계, 이미지 2/2
    • Use a pair of tweezers to remove the front camera and sensor assembly.
  31. Google Pixel 4 Side Buttons Replacement, Remove the vibration motor cover: 31 단계, 이미지 1/1
    • Remove the two T3 Torx screws securing the vibration motor cover:
    • One 4.2 mm screw
    • One 4.4 mm shouldered screw
  32. Google Pixel 4 Side Buttons Replacement: 32 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement: 32 단계, 이미지 2/2
    • Use a pair of tweezers to remove the vibration motor shield.
  33. Google Pixel 4 Side Buttons Replacement, Disconnect the motherboard press connectors: 33 단계, 이미지 1/3 Google Pixel 4 Side Buttons Replacement, Disconnect the motherboard press connectors: 33 단계, 이미지 2/3 Google Pixel 4 Side Buttons Replacement, Disconnect the motherboard press connectors: 33 단계, 이미지 3/3
    • Use the pointed end of a spudger to disconnect the two rear-facing camera connectors from the motherboard.
    • Disconnect the side buttons connector from the motherboard.
  34. Google Pixel 4 Side Buttons Replacement: 34 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement: 34 단계, 이미지 2/2
    • Disconnect the earpiece speaker connector from the motherboard.
  35. Google Pixel 4 Side Buttons Replacement: 35 단계, 이미지 1/3 Google Pixel 4 Side Buttons Replacement: 35 단계, 이미지 2/3 Google Pixel 4 Side Buttons Replacement: 35 단계, 이미지 3/3
    • Disconnect the left grip sensor connector from the motherboard.
    • Disconnect the charge port connector from the motherboard.
  36. Google Pixel 4 Side Buttons Replacement: 36 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement: 36 단계, 이미지 2/2
    • Disconnect the right grip sensor connector from the motherboard.
    • Disconnect the display connector from the motherboard.
  37. Google Pixel 4 Side Buttons Replacement: 37 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement: 37 단계, 이미지 2/2
    • Use a pair of tweezers to disconnect the antenna connector from the charging assembly by pulling it straight up from the motherboard.
  38. Google Pixel 4 Side Buttons Replacement: 38 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement: 38 단계, 이미지 2/2
    • Disconnect the bottom microphone connector from the motherboard.
  39. Google Pixel 4 Side Buttons Replacement, Remove the motherboard: 39 단계, 이미지 1/3 Google Pixel 4 Side Buttons Replacement, Remove the motherboard: 39 단계, 이미지 2/3 Google Pixel 4 Side Buttons Replacement, Remove the motherboard: 39 단계, 이미지 3/3
    • Slowly lift out the motherboard, being careful not to snag any ribbon cable connectors.
    • The rear-facing camera module connectors loop around the motherboard, and the camera module is not secured to the phone, so it may lift out with the motherboard during this step.
    • Completely remove the motherboard.
    • When reinstalling the motherboard, check that no ribbon cable connectors are caught underneath.
  40. Google Pixel 4 Side Buttons Replacement, Remove the rear-facing camera module: 40 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement, Remove the rear-facing camera module: 40 단계, 이미지 2/2
    • Use a pair of tweezers to remove the rear-facing camera module.
  41. Google Pixel 4 Side Buttons Replacement, Remove the side button flex cable: 41 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement, Remove the side button flex cable: 41 단계, 이미지 2/2
    • Use a pair of tweezers to peel the side button flex cable off of the phone's frame. It is secured with some light adhesive.
  42. Google Pixel 4 Side Buttons Replacement: 42 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement: 42 단계, 이미지 2/2
    • Continue peeling the flex cable until it is no longer adhered to the back side of the phone.
  43. Google Pixel 4 Side Buttons Replacement: 43 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement: 43 단계, 이미지 2/2
    • Use a pair of tweezers to peel away the side button flex cable from the button bracket, on the inside edge of the phone's frame.
    • This process is destructive, so proceed with caution, and have a replacement part ready.
    • Continue to peel away the flex cable until it is no longer adhered to the button bracket.
  44. Google Pixel 4 Side Buttons Replacement: 44 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement: 44 단계, 이미지 2/2
    • With the side button flex cable peeled away from the button bracket, completely remove it.
    • The flex may come out in multiple pieces or rip, so make sure there's nothing left behind.
  45. Google Pixel 4 Side Buttons Replacement, Remove the button bracket: 45 단계, 이미지 1/1
    • Use a T3 Torx driver to remove the two 2.4 mm screws securing the button bracket to the frame.
  46. Google Pixel 4 Side Buttons Replacement: 46 단계, 이미지 1/3 Google Pixel 4 Side Buttons Replacement: 46 단계, 이미지 2/3 Google Pixel 4 Side Buttons Replacement: 46 단계, 이미지 3/3
    • Use a pair of tweezers to remove the button bracket.
  47. Google Pixel 4 Side Buttons Replacement: 47 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement: 47 단계, 이미지 2/2
    • The side button flex cable is adhered to both sides of the button bracket.
    • Using a pair of tweezers, peel away leftover flex cable that's adhered to the back side of the button bracket.
    • The cable is in multiple pieces, so make sure there's nothing left behind.
    • Remove any leftover adhesive before reinstalling a new grip sensor.
  48. Google Pixel 4 Side Buttons Replacement, Installing a new side button flex cable: 48 단계, 이미지 1/2 Google Pixel 4 Side Buttons Replacement, Installing a new side button flex cable: 48 단계, 이미지 2/2
    • When reinstalling a new side button flex cable, align the holes in the flex cable with the holes on the button bracket, remove the adhesive backings, and press to secure.
    • Don't install the new flex cable on the opposite side of the button bracket until you have screwed it back into the phone frame.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Carsten Frauenheim
회원 가입일: 03/10/20
114,107 평판
안내서 338개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,199개 작성하였습니다
댓글 한 개
Really nicely written. Great pictures, too. Only thing I see missing is a link to the replacement flex cable part.
Hill Bass - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 46
30일 전: 177
전체 시간: 7,921
