주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google Pixel 5 Screen Adhesive Installation
필요한 것
  1. Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the frame: 1 단계, 이미지 3개 중 1개 Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the frame: 1 단계, 이미지 3개 중 2개 Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the frame: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Peel off as much adhesive as you can with a pair of tweezers.
    • Use a spudger to scrape away any lingering adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the frame.
    • For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
    댓글 쓰기
  2. Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the screen: 2 단계, 이미지 3개 중 1개 Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the screen: 2 단계, 이미지 3개 중 2개 Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the screen: 2 단계, 이미지 3개 중 3개
    • Repeat the previous step for the screen adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the screen.
    • Don't use isopropyl alcohol near the front camera bracket as it will loosen its adhesive.
    댓글 쓰기
  3. Google Pixel 5 Screen Adhesive Installation, Align the adhesive: 3 단계, 이미지 2개 중 1개 Google Pixel 5 Screen Adhesive Installation, Align the adhesive: 3 단계, 이미지 2개 중 2개
    • Use the holes in the top right and bottom left corners of the frame to correctly align the adhesive:
    • The top right hole is circular
    • The bottom left hole is oblong
    댓글 쓰기
  4. Google Pixel 5 Screen Adhesive Installation, Prepare the adhesive: 4 단계, 이미지 1개 중 1개
    • Peel away the clear plastic lining to expose the frame side of the adhesive.
    댓글 쓰기
  5. Google Pixel 5 Screen Adhesive Installation, Apply the adhesive: 5 단계, 이미지 2개 중 1개 Google Pixel 5 Screen Adhesive Installation, Apply the adhesive: 5 단계, 이미지 2개 중 2개
    • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Lower the adhesive onto the frame.
    • Use the holes in the top right and bottom left corners to properly align the adhesive during installation.
    댓글 쓰기
  6. Google Pixel 5 Screen Adhesive Installation, Secure the adhesive to the frame: 6 단계, 이미지 2개 중 1개 Google Pixel 5 Screen Adhesive Installation, Secure the adhesive to the frame: 6 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger or your fingernail to press down on the adhesive.
    • Slide along the perimeter to secure the adhesive to the frame.
    댓글 쓰기
  7. Google Pixel 5 Screen Adhesive Installation, Peel away the outer plastic lining: 7 단계, 이미지 2개 중 1개 Google Pixel 5 Screen Adhesive Installation, Peel away the outer plastic lining: 7 단계, 이미지 2개 중 2개
    • Use your fingers to grasp the blue plastic lining near the center and peel it away from the phone.
    • This should leave a thin perimeter of adhesive still covered by blue plastic lining.
    댓글 쓰기
  8. Google Pixel 5 Screen Adhesive Installation, Connect the screen: 8 단계, 이미지 2개 중 1개 Google Pixel 5 Screen Adhesive Installation, Connect the screen: 8 단계, 이미지 2개 중 2개
    댓글 쓰기
  9. Google Pixel 5 Screen Adhesive Installation, Peel away the remaining plastic lining: 9 단계, 이미지 2개 중 1개 Google Pixel 5 Screen Adhesive Installation, Peel away the remaining plastic lining: 9 단계, 이미지 2개 중 2개
    • Peel away the blue plastic lining to expose the perimeter adhesive.
    댓글 쓰기
  10. Google Pixel 5 Screen Adhesive Installation, Position the screen: 10 단계, 이미지 3개 중 1개 Google Pixel 5 Screen Adhesive Installation, Position the screen: 10 단계, 이미지 3개 중 2개 Google Pixel 5 Screen Adhesive Installation, Position the screen: 10 단계, 이미지 3개 중 3개
    • Position the screen so it lays on the frame.
    댓글 쓰기
  11. Google Pixel 5 Screen Adhesive Installation, Press down the screen corners: 11 단계, 이미지 2개 중 1개 Google Pixel 5 Screen Adhesive Installation, Press down the screen corners: 11 단계, 이미지 2개 중 2개
    • Press down the corners of the screen to secure them to the frame.
    댓글 쓰기
  12. Google Pixel 5 Screen Adhesive Installation, Secure the screen to the frame: 12 단계, 이미지 3개 중 1개 Google Pixel 5 Screen Adhesive Installation, Secure the screen to the frame: 12 단계, 이미지 3개 중 2개 Google Pixel 5 Screen Adhesive Installation, Secure the screen to the frame: 12 단계, 이미지 3개 중 3개
    • Press down on the edges of the screen.
    • Slide along the perimeter to secure it to the frame.
    • You can heat the perimeter of the screen to soften the adhesive and help it bond more securely.
    댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 5 Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 34명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Chayton Ritter
회원 가입일: 08/21/20
27,084 평판
안내서 105개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 22,190개를 작성함
1가이드 댓글
Vielen Dank für die ausführliche und hilfreiche Anleitung. Hat alles geklappt. Leider hatte ich die Schutzfolie über der Frontkamera übersehen. Die funktioniert jetzt nicht mehr. Das sollte noch in der Anleitung ergänzt werden.
Simon - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 49
지난 30일: 210
전체 시간: 13,657
