주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google Pixel 9 Autofocus and Flash Module Replacement
필요한 것
  1. Google Pixel 9 Autofocus and Flash Module Replacement, Prepare your Pixel for disassembly: 1 단계, 이미지 3개 중 1개 Google Pixel 9 Autofocus and Flash Module Replacement, Prepare your Pixel for disassembly: 1 단계, 이미지 3개 중 2개 Google Pixel 9 Autofocus and Flash Module Replacement, Prepare your Pixel for disassembly: 1 단계, 이미지 3개 중 3개
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
    댓글 쓰기
  2. Google Pixel 9 Autofocus and Flash Module Replacement, Adhesive information: 2 단계, 이미지 3개 중 1개 Google Pixel 9 Autofocus and Flash Module Replacement, Adhesive information: 2 단계, 이미지 3개 중 2개 Google Pixel 9 Autofocus and Flash Module Replacement, Adhesive information: 2 단계, 이미지 3개 중 3개
    • Adhesive secures the perimeter of the back glass to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the back glass to avoid damaging the internal components.
    • To help, measure and mark 3 mm from the tip of an opening pick with a permanent marker.
    • If your screen or back glass is badly cracked, a suction cup may not perfectly adhere.
    • Lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier. Ensure there's a smooth area near the bottom edge that's large and smooth enough for a suction cup to stick to.
    댓글 쓰기
  3. Google Pixel 9 Autofocus and Flash Module Replacement, Apply a suction handle: 3 단계, 이미지 2개 중 1개 Google Pixel 9 Autofocus and Flash Module Replacement, Apply a suction handle: 3 단계, 이미지 2개 중 2개
    • Place a suction handle at the bottom edge of the back glass, as close to the edge as possible.
    • Push down to attach the suction cup.
    댓글 쓰기
  4. Google Pixel 9 Autofocus and Flash Module Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 1개 Google Pixel 9 Autofocus and Flash Module Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 2개 Google Pixel 9 Autofocus and Flash Module Replacement, Insert an opening pick: 4 단계, 이미지 3개 중 3개
    • Pull up on the suction handle with strong, steady force to create a small gap under the back glass.
    • Insert the tip of an opening pick into the gap.
    댓글 쓰기
  5. Google Pixel 9 Autofocus and Flash Module Replacement, Separate the back glass adhesive: 5 단계, 이미지 3개 중 1개 Google Pixel 9 Autofocus and Flash Module Replacement, Separate the back glass adhesive: 5 단계, 이미지 3개 중 2개 Google Pixel 9 Autofocus and Flash Module Replacement, Separate the back glass adhesive: 5 단계, 이미지 3개 중 3개
    • Slide the opening pick back and forth along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
    댓글 쓰기
  6. Google Pixel 9 Autofocus and Flash Module Replacement: 6 단계, 이미지 3개 중 1개 Google Pixel 9 Autofocus and Flash Module Replacement: 6 단계, 이미지 3개 중 2개 Google Pixel 9 Autofocus and Flash Module Replacement: 6 단계, 이미지 3개 중 3개
    • Slide the opening pick around the perimeter of the phone, slicing the rest of the adhesive.
    댓글 쓰기
  7. Google Pixel 9 Autofocus and Flash Module Replacement: 7 단계, 이미지 3개 중 1개 Google Pixel 9 Autofocus and Flash Module Replacement: 7 단계, 이미지 3개 중 2개 Google Pixel 9 Autofocus and Flash Module Replacement: 7 단계, 이미지 3개 중 3개
    • With most of the adhesive separated, lightly twist the opening pick at the bottom edge to lift the back glass up until you can grip it with your fingers.
    • Use the opening pick to separate any remaining sections of adhesive securing the back glass.
    댓글 쓰기
  8. Google Pixel 9 Autofocus and Flash Module Replacement, Remove the back glass: 8 단계, 이미지 1개 중 1개
    • Remove the back glass.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your back glass.
    댓글 쓰기
  9. Google Pixel 9 Autofocus and Flash Module Replacement, Remove the upper board cover: 9 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    FixMat
    $36.95
    • While the Pixel 9 uses Torx Plus screws, standard Torx bits also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a 3IP Torx Plus driver to remove the single 5.4 mm‑long screw securing the upper board cover.
    댓글 쓰기
  10. Google Pixel 9 Autofocus and Flash Module Replacement: 10 단계, 이미지 2개 중 1개 Google Pixel 9 Autofocus and Flash Module Replacement: 10 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to remove the upper board cover.
    댓글 쓰기
  11. Google Pixel 9 Autofocus and Flash Module Replacement, Remove the midframe: 11 단계, 이미지 1개 중 1개
    • Use a 3IP Torx driver to remove the five screws securing the midframe and wireless charging coil:
    • Four 5.4 mm-long screws
    • One 2.2 mm-long screw
    댓글 쓰기
  12. Google Pixel 9 Autofocus and Flash Module Replacement, Peel up the flash cable: 12 단계, 이미지 2개 중 1개 Google Pixel 9 Autofocus and Flash Module Replacement, Peel up the flash cable: 12 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to peel the flash cable off of the metal midframe.
    댓글 쓰기
  13. Google Pixel 9 Autofocus and Flash Module Replacement, Remove the midframe: 13 단계, 이미지 2개 중 1개 Google Pixel 9 Autofocus and Flash Module Replacement, Remove the midframe: 13 단계, 이미지 2개 중 2개
    • Remove the midframe, wireless charging coil, and NFC assembly.
    댓글 쓰기
  14. Google Pixel 9 Autofocus and Flash Module Replacement, Disconnect the battery: 14 단계, 이미지 2개 중 1개 Google Pixel 9 Autofocus and Flash Module Replacement, Disconnect the battery: 14 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry up and disconnect the battery connector.
    댓글 쓰기
  15. Google Pixel 9 Autofocus and Flash Module Replacement, Remove the antenna board cover: 15 단계, 이미지 1개 중 1개
    • Use a 3IP Torx Plus driver to remove the 5.4 mm-long screw securing the antenna board cover.
    댓글 쓰기
  16. Google Pixel 9 Autofocus and Flash Module Replacement: 16 단계, 이미지 1개 중 1개
    • Use a pair of tweezers to remove the antenna board cover.
    댓글 쓰기
  17. Google Pixel 9 Autofocus and Flash Module Replacement, Disconnect the autofocus cable: 17 단계, 이미지 2개 중 1개 Google Pixel 9 Autofocus and Flash Module Replacement, Disconnect the autofocus cable: 17 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry up and disconnect the autofocus connector from the motherboard.
    댓글 쓰기
  18. Google Pixel 9 Autofocus and Flash Module Replacement, Disconnect the flash: 18 단계, 이미지 2개 중 1개 Google Pixel 9 Autofocus and Flash Module Replacement, Disconnect the flash: 18 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry up and disconnect the flash connector from the motherboard.
    댓글 쓰기
  19. Google Pixel 9 Autofocus and Flash Module Replacement, Heat the LDAF adhesive: 19 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it over the LDAF and flash module for one minute to soften the adhesive securing it to the rear camera module.
    댓글 쓰기
  20. Google Pixel 9 Autofocus and Flash Module Replacement, Remove the LDAF and flash module: 20 단계, 이미지 3개 중 1개 Google Pixel 9 Autofocus and Flash Module Replacement, Remove the LDAF and flash module: 20 단계, 이미지 3개 중 2개 Google Pixel 9 Autofocus and Flash Module Replacement, Remove the LDAF and flash module: 20 단계, 이미지 3개 중 3개
    • Peel up and remove the LDAF and flash module.
    • During reassembly, orient the module such that the longer cable is on the bottom edge.
    • Be very careful not to touch the rear camera lenses. If you accidentally do, wipe them with a clean microfiber cloth.
    댓글 쓰기
  21. Google Pixel 9 Autofocus and Flash Module Replacement, Reassembly information: 21 단계, 이미지 3개 중 1개 Google Pixel 9 Autofocus and Flash Module Replacement, Reassembly information: 21 단계, 이미지 3개 중 2개 Google Pixel 9 Autofocus and Flash Module Replacement, Reassembly information: 21 단계, 이미지 3개 중 3개
    • Use a spudger and tweezers to remove the two pieces of adhesive from the bottom of the LDAF and flash module.
    • Remove the larger clear liners from one of the flash module adhesives.
    • Place the adhesive into place on the bottom of the module and press down firmly with the flat end of a spudger to secure the adhesive.
    • Repeat the process to apply the other piece of flash adhesive.
    • Remove the two remaining blue liners.
    댓글 쓰기
결론
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 9 Answers Community for help.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Carsten Frauenheim
회원 가입일: 03/10/20
167,350 평판
안내서 439개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 28,237개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 99
전체 시간: 1,573
