주요 콘텐츠로 건너뛰기
Google Pixel 9 Screen Replacement
필요한 것
  1. Google Pixel 9 Screen Replacement, Prepare your Pixel for disassembly: 1 단계, 이미지 3개 중 1개 Google Pixel 9 Screen Replacement, Prepare your Pixel for disassembly: 1 단계, 이미지 3개 중 2개 Google Pixel 9 Screen Replacement, Prepare your Pixel for disassembly: 1 단계, 이미지 3개 중 3개
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Google Pixel 9 Screen Replacement, Tape over any cracks: 2 단계, 이미지 2개 중 1개 Google Pixel 9 Screen Replacement, Tape over any cracks: 2 단계, 이미지 2개 중 2개
    • Glass shards can complicate disassembly—or worse, cause injury. If your phone has a cracked screen, follow these steps:
    • Apply overlapping strips of packing tape to the cracked glass until the whole screen is covered—this will allow the suction cup to stick to the screen.
    • Only cover the glass itself—don't stick any tape to the frame.
    • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
  3. Google Pixel 9 Screen Replacement: 3 단계, 이미지 3개 중 1개 Google Pixel 9 Screen Replacement: 3 단계, 이미지 3개 중 2개 Google Pixel 9 Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Adhesive secures the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
    • Use a hair dryer, heat gun, or hot plate to heat the entire screen until it's almost too hot to touch.
    • Be careful not to overheat the phone—the battery and plastic components are susceptible to heat damage. Stop heating if the frame becomes too hot to touch.
  4. Google Pixel 9 Screen Replacement, Apply a suction handle: 4 단계, 이미지 2개 중 1개 Google Pixel 9 Screen Replacement, Apply a suction handle: 4 단계, 이미지 2개 중 2개
    • Apply a suction handle to the center of the screen's top edge.
  5. Google Pixel 9 Screen Replacement, Screen information: 5 단계, 이미지 3개 중 1개 Google Pixel 9 Screen Replacement, Screen information: 5 단계, 이미지 3개 중 2개 Google Pixel 9 Screen Replacement, Screen information: 5 단계, 이미지 3개 중 3개
    • There are delicate metal spring‑contacts around the perimeter of your device. To prevent damaging them when separating the screen, don't insert your pick more than 3 mm deep.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  6. Google Pixel 9 Screen Replacement, Insert an opening pick: 6 단계, 이미지 3개 중 1개 Google Pixel 9 Screen Replacement, Insert an opening pick: 6 단계, 이미지 3개 중 2개 Google Pixel 9 Screen Replacement, Insert an opening pick: 6 단계, 이미지 3개 중 3개
    • Inserting an opening pick is difficult. Be patient and reheat the screen at any point if it feels stuck.
    • Pull up on the suction handle with strong, steady force to create a gap between the screen and frame.
    • Insert the tip of an opening pick under the screen.
    • A plastic frame is attached to the backside of the display. When inserting your pick, make sure it's underneath this frame, and not between the frame and the display glass.
  7. Google Pixel 9 Screen Replacement, Separate the screen adhesive: 7 단계, 이미지 3개 중 1개 Google Pixel 9 Screen Replacement, Separate the screen adhesive: 7 단계, 이미지 3개 중 2개 Google Pixel 9 Screen Replacement, Separate the screen adhesive: 7 단계, 이미지 3개 중 3개
    • Slide the opening pick along the top edge to separate the adhesive securing it.
  8. Google Pixel 9 Screen Replacement: 8 단계, 이미지 3개 중 1개 Google Pixel 9 Screen Replacement: 8 단계, 이미지 3개 중 2개 Google Pixel 9 Screen Replacement: 8 단계, 이미지 3개 중 3개
    • Continue sliding your opening pick around the perimeter of the screen to separate the remaining adhesive.
  9. Google Pixel 9 Screen Replacement, Prop up the screen: 9 단계, 이미지 3개 중 1개 Google Pixel 9 Screen Replacement, Prop up the screen: 9 단계, 이미지 3개 중 2개 Google Pixel 9 Screen Replacement, Prop up the screen: 9 단계, 이미지 3개 중 3개
    • Flip the screen over the right edge of your phone and prop it up with the suction handle.
    • Be careful not to strain the display cable, located near the bottom right corner.
    • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
  10. Google Pixel 9 Screen Replacement, Disconnect the screen: 10 단계, 이미지 3개 중 1개 Google Pixel 9 Screen Replacement, Disconnect the screen: 10 단계, 이미지 3개 중 2개 Google Pixel 9 Screen Replacement, Disconnect the screen: 10 단계, 이미지 3개 중 3개
    • Use angled tweezers to pry up the top edge of the screen cable bracket.
    • Remove the bracket.
  11. Google Pixel 9 Screen Replacement: 11 단계, 이미지 3개 중 1개 Google Pixel 9 Screen Replacement: 11 단계, 이미지 3개 중 2개 Google Pixel 9 Screen Replacement: 11 단계, 이미지 3개 중 3개
    • Be very careful not to damage any of the small, surface‑mounted components around the screen's press connector.
    • Insert the point of a spudger under the left edge of the screen cable press connector and pry up to disconnect it.
    • Remove the screen.
  12. Google Pixel 9 Screen Replacement, Screen information: 12 단계, 이미지 1개 중 1개
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
  13. Google Pixel 9 Screen Replacement, Remove all the old screen adhesive: 13 단계, 이미지 3개 중 1개 Google Pixel 9 Screen Replacement, Remove all the old screen adhesive: 13 단계, 이미지 3개 중 2개 Google Pixel 9 Screen Replacement, Remove all the old screen adhesive: 13 단계, 이미지 3개 중 3개
    • When removing the screen adhesive during this step, be very careful not to damage any of the fragile components near the perimeter of the frame.
    • Use a spudger to scrape up and remove all the old screen adhesive from the perimeter of the frame.
    • This will take some time as the adhesive can be tricky to remove. Work slowly and try to roll the adhesive onto itself.
    • Once you've removed all the old adhesive, use isopropyl alcohol and a microfiber cloth to clean up the adhesive residue from the perimeter of the frame.
    • In order for the new adhesive to form a good bond, the frame needs to be completely clean of all adhesive and its residue.
    • Allow the frame to dry completely before continuing.
  14. Google Pixel 9 Screen Replacement, Orient the adhesive: 14 단계, 이미지 3개 중 1개 Google Pixel 9 Screen Replacement, Orient the adhesive: 14 단계, 이미지 3개 중 2개 Google Pixel 9 Screen Replacement, Orient the adhesive: 14 단계, 이미지 3개 중 3개
    • If your replacement screen has adhesive pre‑installed, skip down seven steps. Otherwise, follow the next seven steps to install new screen adhesive.
    • Before applying the adhesive, make sure you know its proper orientation on the frame. Hold the adhesive over your phone to find its proper alignment.
    • The blue liner should be facing up, with the larger clear liner on the bottom.
    • The adhesive has a corresponding groove on the perimeter of the frame.
    • Cutouts in the blue liner correspond to spring contacts on the frame.
  15. Google Pixel 9 Screen Replacement, Apply the screen adhesive: 15 단계, 이미지 1개 중 1개
    • Peel down the top half of the larger, clear liner to expose the adhesive—don't remove the whole liner yet.
  16. Google Pixel 9 Screen Replacement: 16 단계, 이미지 2개 중 1개 Google Pixel 9 Screen Replacement: 16 단계, 이미지 2개 중 2개
    • Take your time aligning the adhesive with the frame—it's very sticky and can't be moved after you apply it.
    • Keep the larger, clear liner folded towards the bottom of the phone during this step.
    • Lay the exposed top edge of the adhesive onto the frame, using the frame's lip to help align it.
    • Once the top edge is properly aligned, gently press down with your fingers to secure it in place.
  17. Google Pixel 9 Screen Replacement: 17 단계, 이미지 3개 중 1개 Google Pixel 9 Screen Replacement: 17 단계, 이미지 3개 중 2개 Google Pixel 9 Screen Replacement: 17 단계, 이미지 3개 중 3개
    • Slowly lay the rest of the adhesive onto the frame, peeling away the larger clear liner as you go.
  18. Google Pixel 9 Screen Replacement, Secure the screen adhesive: 18 단계, 이미지 3개 중 1개 Google Pixel 9 Screen Replacement, Secure the screen adhesive: 18 단계, 이미지 3개 중 2개 Google Pixel 9 Screen Replacement, Secure the screen adhesive: 18 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to firmly press around the perimeter of the adhesive to secure it to the frame.
  19. Google Pixel 9 Screen Replacement: 19 단계, 이미지 2개 중 1개 Google Pixel 9 Screen Replacement: 19 단계, 이미지 2개 중 2개
    • Use tweezers to grip the top left corner of the blue liner and remove it.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it.
  20. Google Pixel 9 Screen Replacement: 20 단계, 이미지 3개 중 1개 Google Pixel 9 Screen Replacement: 20 단계, 이미지 3개 중 2개 Google Pixel 9 Screen Replacement: 20 단계, 이미지 3개 중 3개
  21. Google Pixel 9 Screen Replacement, Connect the replacement screen: 21 단계, 이미지 1개 중 1개
    • Carefully lay your replacement screen display‑side‑down just to the right of your phone so you can reconnect the cable.
  22. Google Pixel 9 Screen Replacement: 22 단계, 이미지 2개 중 1개 Google Pixel 9 Screen Replacement: 22 단계, 이미지 2개 중 2개
    • Be very careful not to strain the screen cable during this step. You may need to hold the screen up at an angle to help position the cable.
    • Align the screen press connector over its socket and gently press down on one side until it clicks into place, then press down on the other side.
    • Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    • Hook the bottom edge of the screen cable bracket into its cutout and firmly press down on the top edge until the bracket clicks into place.
  23. Google Pixel 9 Screen Replacement, Remove any small liners: 23 단계, 이미지 3개 중 1개 Google Pixel 9 Screen Replacement, Remove any small liners: 23 단계, 이미지 3개 중 2개 Google Pixel 9 Screen Replacement, Remove any small liners: 23 단계, 이미지 3개 중 3개
    • Leave the perimeter display adhesive liners in place for now.
    • Thoroughly check your replacement screen for any small plastic liners (specifically near the front facing camera and screen cable) and use your fingers to remove them—you can identify the liners by their plastic pull tabs.
    • Be very careful not to damage the screen when removing the liners.
  24. Google Pixel 9 Screen Replacement, Remove the screen adhesive liner: 24 단계, 이미지 3개 중 1개 Google Pixel 9 Screen Replacement, Remove the screen adhesive liner: 24 단계, 이미지 3개 중 2개 Google Pixel 9 Screen Replacement, Remove the screen adhesive liner: 24 단계, 이미지 3개 중 3개
    • Follow this step only if your screen has adhesive pre‑installed on the underside.
    • Use tweezers or your fingers to remove the two remaining blue liners from the underside of the screen.
    • Skip the next step.
  25. Google Pixel 9 Screen Replacement: 25 단계, 이미지 3개 중 1개 Google Pixel 9 Screen Replacement: 25 단계, 이미지 3개 중 2개 Google Pixel 9 Screen Replacement: 25 단계, 이미지 3개 중 3개
    • Follow this step if you applied screen adhesive directly to the frame.
    • Use tweezers or your fingers to remove the two remaining liners from the frame. You'll need to carefully hold the screen up to remove the right liner.
  26. Google Pixel 9 Screen Replacement, Secure the screen with its adhesive: 26 단계, 이미지 2개 중 1개 Google Pixel 9 Screen Replacement, Secure the screen with its adhesive: 26 단계, 이미지 2개 중 2개
    • Carefully flip the screen onto the frame.
  27. Google Pixel 9 Screen Replacement: 27 단계, 이미지 3개 중 1개 Google Pixel 9 Screen Replacement: 27 단계, 이미지 3개 중 2개 Google Pixel 9 Screen Replacement: 27 단계, 이미지 3개 중 3개
    • Firmly press around the perimeter of the screen to secure it to the frame.
    • When powering on your Pixel for the first time after your repair, make sure the phone is laying flat and nothing is touching the screen (fingers, plastic liners, screen protectors, cases).
결론
Congratulations on completing your screen repair!
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
To calibrate the display’s fingerprint reader, use Google’s Pixel Update and Software Repair tool.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Carsten Frauenheim
회원 가입일: 03/10/20
155,196 평판
안내서 439개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,589개를 작성함
6가이드 댓글
I made this repair last night and while I think your guide is substantially complete, there is a very significant detail omitted- the replacement screen from ifixit comes with tape over the front camera glass. I assembled my phone this way, turned it on, and the front camera didn't work. I removed the new screen, removed the cover over the glass, and put it all back together, and damaged the brand new screen upon removal. I basically paid $215 to trade the cracked screen for one that has significant portions of the screen that do not work now. It's really heartbreaking that this step is not outlined in the repair, because now I have to decide if I spend ANOTHER $210 to put on a screen that works, or just deal with a brand new, broken phone, that's just broken in a different way.
Travis K - 답글
Hi Travis. I'm sorry to hear about the damaged new screen and frustrating process of figuring that out. Is the tape you're talking about different from the tape the guide says to remove in step 24?
Spencer Day -
Bonjour, j'ai reçu pour mon pixel 7 et les outils une poche noir avec un liquide dedans, je l'ai ouvert ne ça ne ressemble à rien de fonctionnelle , quelle est sont utilité.
Merci
Eric Fragnol
fragnol eric - 답글
Merci
ERIC FRAGNOL
fragnol eric - 답글
The repair worked for me. Display is now working again. The guide says that I have to calibrate the fingerprint sensor with the Google Update and Repair Tool. But this step fails with the message: "Couldn't find the unique calibration software for this device". Any suggestions on this? Driver for the Pixel is installed and USB-Debugging is activated.
Patrick Schönherr - 답글
댓글 쓰기
조회 통계:
지난 24시간: 46
지난 7일: 298
지난 30일: 1,186
전체 시간: 13,580
