주요 콘텐츠로 건너뛰기
Google Pixel Watch 4 Battery Replacement
필요한 것
  1. Google Pixel Watch 4 Battery Replacement, Prepare your watch for disassembly: 1 단계, 이미지 3개 중 1개 Google Pixel Watch 4 Battery Replacement, Prepare your watch for disassembly: 1 단계, 이미지 3개 중 2개 Google Pixel Watch 4 Battery Replacement, Prepare your watch for disassembly: 1 단계, 이미지 3개 중 3개
    • Before starting your repair:
    • Remove your watch from the charger.
    • Press and hold the crown button, then tap Power off to shut down your watch.
  2. Google Pixel Watch 4 Battery Replacement, Remove the watch bands: 2 단계, 이미지 3개 중 1개 Google Pixel Watch 4 Battery Replacement, Remove the watch bands: 2 단계, 이미지 3개 중 2개 Google Pixel Watch 4 Battery Replacement, Remove the watch bands: 2 단계, 이미지 3개 중 3개
    • Remove each watch band by depressing the release button and sliding the band out of its groove.
  3. Google Pixel Watch 4 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Throughout the rest of your repair, consider placing your watch on something soft like a clean cloth to help stabilize it and prevent scratches to the front glass.
  4. Google Pixel Watch 4 Battery Replacement, Remove the back sensor glass screws: 4 단계, 이미지 3개 중 1개 Google Pixel Watch 4 Battery Replacement, Remove the back sensor glass screws: 4 단계, 이미지 3개 중 2개 Google Pixel Watch 4 Battery Replacement, Remove the back sensor glass screws: 4 단계, 이미지 3개 중 3개
    • Use a Torx Plus 2IP screwdriver to remove the 3.0 mm‑long screw from both watch band grooves (two screws total).
    • Both screws have a tiny O‑ring. If they don't lift away with the screw, use a pair of tweezers to carefully remove them from the band groove and set them aside. These O-rings are required to maintain waterproofing.
    • Handle these O-rings carefully. Avoid pinching or slicing them with your tool.
    • During reassembly:
    • Make sure the O‑rings are on the screws before installing them.
    • Push down firmly on the back glass while installing the screws to make sure the glass gets properly seated.
    • If there's a gap between the back glass and frame, remove the screws and reinstall them.
  5. Google Pixel Watch 4 Battery Replacement, Separate the back sensor glass: 5 단계, 이미지 2개 중 1개 Google Pixel Watch 4 Battery Replacement, Separate the back sensor glass: 5 단계, 이미지 2개 중 2개
    • Insert the point of a spudger (or a clean fingernail) into the seam between the back sensor glass and frame and pry up until the cover detaches.
  6. Google Pixel Watch 4 Battery Replacement, Reposition the back sensor glass: 6 단계, 이미지 3개 중 1개 Google Pixel Watch 4 Battery Replacement, Reposition the back sensor glass: 6 단계, 이미지 3개 중 2개 Google Pixel Watch 4 Battery Replacement, Reposition the back sensor glass: 6 단계, 이미지 3개 중 3개
    • Gently lift the back glass and flip it over the side of the watch opposite the crown.
    • Be careful not to strain the cable connecting the back sensor glass.
  7. Google Pixel Watch 4 Battery Replacement, Remove the vibration motor screws: 7 단계, 이미지 2개 중 1개 Google Pixel Watch 4 Battery Replacement, Remove the vibration motor screws: 7 단계, 이미지 2개 중 2개
    • Optionally, you can disconnect the back glass to give you more room to work—though you can complete the repair just fine with it still connected.
    • Use a Torx Plus 2IP screwdriver to remove the two 2.2 mm‑long screws securing the vibration motor.
  8. Google Pixel Watch 4 Battery Replacement, Remove the vibration motor: 8 단계, 이미지 2개 중 1개 Google Pixel Watch 4 Battery Replacement, Remove the vibration motor: 8 단계, 이미지 2개 중 2개
  9. Google Pixel Watch 4 Battery Replacement, Reposition the back sensor glass: 9 단계, 이미지 3개 중 1개 Google Pixel Watch 4 Battery Replacement, Reposition the back sensor glass: 9 단계, 이미지 3개 중 2개 Google Pixel Watch 4 Battery Replacement, Reposition the back sensor glass: 9 단계, 이미지 3개 중 3개
    • Gently flip the back sensor glass over the crown-side of the watch.
  10. Google Pixel Watch 4 Battery Replacement, Disconnect the battery: 10 단계, 이미지 2개 중 1개 Google Pixel Watch 4 Battery Replacement, Disconnect the battery: 10 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the battery press connector.
    • During reassembly, use the point of a spudger to press down and reconnect the press connector.
    • This can be tricky, and may take a few tries.
    • If you're having trouble, loosen the two battery screws and reposition the connector. Once connected, re-tighten the battery screws.
  11. Google Pixel Watch 4 Battery Replacement, Remove the battery screws: 11 단계, 이미지 2개 중 1개 Google Pixel Watch 4 Battery Replacement, Remove the battery screws: 11 단계, 이미지 2개 중 2개
    • Use a Torx Plus 2IP screwdriver to remove the two 2.2 mm‑long screws securing the battery.
  12. Google Pixel Watch 4 Battery Replacement, Remove the battery: 12 단계, 이미지 3개 중 1개 Google Pixel Watch 4 Battery Replacement, Remove the battery: 12 단계, 이미지 3개 중 2개 Google Pixel Watch 4 Battery Replacement, Remove the battery: 12 단계, 이미지 3개 중 3개
    • Remove the battery.
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
149,525 평판
안내서 995개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 27
지난 7일: 158
지난 30일: 559
전체 시간: 1,659
