주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GravityLight LED Replacement
필요한 것
    1. GravityLight LED Replacement, Removing the Front Panel: 1 단계, 이미지 2개 중 1개 GravityLight LED Replacement, Removing the Front Panel: 1 단계, 이미지 2개 중 2개
      • Flip the GravityLight on its back and place it on a sturdy surface.
      • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
      댓글 쓰기
    2. GravityLight LED Replacement, Opening the Device Housing: 2 단계, 이미지 1개 중 1개
      • Some of the internal pieces may loosen or fall out during disassembly.
      • Firmly grasp both parts of the GravityLight body and pull them apart.
      댓글 쓰기
    1. GravityLight LED Replacement, Removing the Back Panel Screws: 3 단계, 이미지 1개 중 1개
      • Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
      • Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
      댓글 쓰기
    2. GravityLight LED Replacement, Removing the LED Housing: 4 단계, 이미지 2개 중 1개 GravityLight LED Replacement, Removing the LED Housing: 4 단계, 이미지 2개 중 2개
      • Hold the LED housing in your hand, but do not separate it too far otherwise you will tear the wires.
      • Lift the LED housing away from the back panel.
      댓글 쓰기
    3. GravityLight LED Replacement, Remove the White Gear from the LED Housing: 5 단계, 이미지 2개 중 1개 GravityLight LED Replacement, Remove the White Gear from the LED Housing: 5 단계, 이미지 2개 중 2개
      • Grab the outside of the large, white gear in the LED housing and pull the gear out of the housing.
      댓글 쓰기
    4. GravityLight LED Replacement, Position the LED Housing: 6 단계, 이미지 1개 중 1개
      • Set the LED housing flat on a sturdy surface so that the back of the LED and the wires are exposed.
      댓글 쓰기
    5. GravityLight LED Replacement, Cut the Wires: 7 단계, 이미지 1개 중 1개
      • Place the GravityLight's back panel aside.
      • Use the Flush Wire Cutter to cut both the purple wire and the red wire that connect to the LED.
      댓글 쓰기
    6. GravityLight LED Replacement, Bend the LED Leads: 8 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Take tweezers and bend the leads (the silver wires coming out of the bulb) so that the leads are straight.
      • The straight leads will make the LED easier to take out.
      댓글 쓰기
    7. GravityLight LED Replacement, Remove the LED: 9 단계, 이미지 1개 중 1개
      • Flip the LED housing over.
      • Pull the LED out with tweezers.
      댓글 쓰기
    8. GravityLight LED Replacement, Soldering the New LED: 10 단계, 이미지 1개 중 1개
      • For reassembly: Flip the LED housing back over.
      • Put the new LED in its spot. Solder the red wire and the purple wire back onto the new leads.
      • Make sure that you pair each wire to the correct lead. If the LED still does not light, switch the wires on the leads.
      • For information on how to solder look here: 연결부 납땜 및 납제거 방법
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Brian Gouldsberry
회원 가입일: 09/26/14
201 평판
안내서 2개를 작성함
Cal Poly, Team 12-2, Forte Fall 2014 Cal Poly, Team 12-2, Forte Fall 2014 회원
CPSU-FORTE-F14S12G2
5 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 26
전체 시간: 1,022
