주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HMDX Chill Charging Port Replacement
필요한 것
  1. HMDX Chill Charging Port Replacement, Remove Rubber Base: 1 단계, 이미지 3개 중 1개 HMDX Chill Charging Port Replacement, Remove Rubber Base: 1 단계, 이미지 3개 중 2개 HMDX Chill Charging Port Replacement, Remove Rubber Base: 1 단계, 이미지 3개 중 3개
    • Insert a metal spudger under the rubber base.
    • Pry the rubber base off.
    댓글 쓰기
  2. HMDX Chill Charging Port Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
    댓글 쓰기
  3. HMDX Chill Charging Port Replacement: 3 단계, 이미지 2개 중 1개 HMDX Chill Charging Port Replacement: 3 단계, 이미지 2개 중 2개
    • Grip the base of the HMDX Chill.
    • Pull the base upwards.
    댓글 쓰기
  4. HMDX Chill Charging Port Replacement, Motherboard: 4 단계, 이미지 3개 중 1개 HMDX Chill Charging Port Replacement, Motherboard: 4 단계, 이미지 3개 중 2개 HMDX Chill Charging Port Replacement, Motherboard: 4 단계, 이미지 3개 중 3개
    • Use a Phillips #1 screwdriver to remove the four 6 mm screws that secure the motherboard to the base of the device.
    댓글 쓰기
  5. HMDX Chill Charging Port Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the motherboard away from the base gently.
    • Do not pull too hard on the motherboard. It is still attached to the base by wires.
    댓글 쓰기
  6. HMDX Chill Charging Port Replacement: 6 단계, 이미지 3개 중 1개 HMDX Chill Charging Port Replacement: 6 단계, 이미지 3개 중 2개 HMDX Chill Charging Port Replacement: 6 단계, 이미지 3개 중 3개
    • Use a soldering iron to desolder the wires connecting the motherboard to the case.
    댓글 쓰기
  7. HMDX Chill Charging Port Replacement: 7 단계, 이미지 2개 중 1개 HMDX Chill Charging Port Replacement: 7 단계, 이미지 2개 중 2개
    • Insert the spudger between the case and the wire and move the spudger upwards.
    • This will cause the case to prop open.
    • The wire behind the motherboard will now be visible. Pull this out from behind.
    댓글 쓰기
  8. HMDX Chill Charging Port Replacement: 8 단계, 이미지 1개 중 1개
    • Use the soldering iron to desolder the wires connecting the motherboard to the base of the HMDX Chill.
    댓글 쓰기
  9. HMDX Chill Charging Port Replacement, Desolder the Charging Port: 9 단계, 이미지 2개 중 1개 HMDX Chill Charging Port Replacement, Desolder the Charging Port: 9 단계, 이미지 2개 중 2개
    • Using a soldering tool, desolder the charging port from the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Jourdan Holubasch
회원 가입일: 03/31/16
759 평판
안내서 7개를 작성함
EWU-Giguere-S16S1G1 EWU-Giguere-S16S1G1 회원
Community
4 회원들
안내서 7개를 작성함
1가이드 댓글
I have the charging port removed. Where do I find a replacement??
Aaron Hughes - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 24
전체 시간: 757
