주요 콘텐츠로 건너뛰기
HP 24-G014 disassembly
Hayden
Hayden2 다른 기여자
최종 수정일 June 24, 2024
예상시간 없음
조정
커뮤니티-기여 안내서
This Guide will show you how to get inside of the HP 24-G014 All in one Desktop.
  1. HP 24-G014 disassembly, The Stand: 1 단계, 이미지 2개 중 1개 HP 24-G014 disassembly, The Stand: 1 단계, 이미지 2개 중 2개
    • Flipping the device over here we see two Philips screws holding the stand to the computer.
    • Using a basic screw driver you will most likely find in your garage or a junk drawer we can remove these two screws.
  2. HP 24-G014 disassembly, Removing said stand: 2 단계, 이미지 1개 중 1개
    • After removing the two screws you can pull off the stand.
  3. HP 24-G014 disassembly, Remove the screw inside the stand slot: 3 단계, 이미지 2개 중 1개 HP 24-G014 disassembly, Remove the screw inside the stand slot: 3 단계, 이미지 2개 중 2개
    • Inside the stand slot there is an extra screw using the same screw driver remove the screw.
  4. HP 24-G014 disassembly: 4 단계, 이미지 3개 중 1개 HP 24-G014 disassembly: 4 단계, 이미지 3개 중 2개 HP 24-G014 disassembly: 4 단계, 이미지 3개 중 3개
    • After the screw in the stand slot is removed there are clips holding the display to the body of the system.
    • Using a prying tool such as an iFixit metal spudger or Jimmy tool you can lift the display from the body.
    • Don’t worry about accidentally striking the components as they are pretty far away except for the bottom since the speakers are there.
    • One last thing before going to the other step. I highly don’t recommend using something such as a big flat head screw driver, butter knife, or sharp knifes. But if you must you can use them.
  5. HP 24-G014 disassembly, Removing the Display from the body.: 5 단계, 이미지 1개 중 1개
    • After unclipping the display from the body be very gentle! As there are wires and a display connector attached to the screen.
    • To prevent damage you should open the system from bottom to top (where the HP logo is).
결론
That’s it you’re done!
I am not responsible for any damages done to your device if you break it during repair.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Hayden
회원 가입일: 07/11/21
269 평판
안내서 1개를 작성함
The Odyssey Repair Group The Odyssey Repair Group 회원
Community
2 회원들
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 41
지난 30일: 141
전체 시간: 6,405
