주요 콘텐츠로 건너뛰기
HP 310-1037 Hard Drive Replacement
필요한 것
  1. HP 310-1037 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3개 중 1개 HP 310-1037 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3개 중 2개 HP 310-1037 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3개 중 3개
    • HP310-1037 Touchsmart PC with a dead hard drive. The hard drive is located behind the stand cover.
    • Lay the PC flat on the front to gain access to the stand cover
    • Remove the single screw that holds the stand cover to the chassis with a flat tip screwdriver
  2. HP 310-1037 Hard Drive Replacement: 2 단계, 이미지 3개 중 1개 HP 310-1037 Hard Drive Replacement: 2 단계, 이미지 3개 중 2개 HP 310-1037 Hard Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the stand cover
    • The hard drive caddy is held in place with 1 Phillips screw
    • Use a #0 Phillips screwdriver to remove that screw
  3. HP 310-1037 Hard Drive Replacement: 3 단계, 이미지 3개 중 1개 HP 310-1037 Hard Drive Replacement: 3 단계, 이미지 3개 중 2개 HP 310-1037 Hard Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Lift the handle on the hard drive caddy
    • and pull it to the backside. This will remove the hard drive caddy from the computer.
    • To remove the hard drive from the caddy, turn it over. There are four Phillips scres that hold the hard drive in place.
  4. HP 310-1037 Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 HP 310-1037 Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Once the four screws are removed, slide the hard drive out of the caddy.
    • Here is the failed drive. It is a Hitachi HDS721010CLA332. Failure with this drive is all to common.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
oldturkey03
회원 가입일: 09/29/10
812,408 평판
안내서 119개를 작성함
Global Fixers Global Fixers 회원
Community
45 회원들
안내서 702개를 작성함
댓글 2개
This one made me laugh - Remove two screws. Pull the drive out. Difficulty: Moderate.
LOL
Justin Coope - 답글
Used this guide to get my failing hard drive, thanks!
AdamG - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 29
전체 시간: 5,024
