주요 콘텐츠로 건너뛰기
HP 310-1037 Hard Drive Replacement
oldturkey03
oldturkey03다른 한 명의 기여자
최종 수정일 January 3, 2018
10 - 15 분
조정
추천 가이드
커뮤니티-기여 안내서
Here is a HP 310-1037 with a failed hard drive. The Hitachit 1TB hard drive is a common item to fail. The repalcement is very easy and not hidden screws or adhesive. All that is needed is a flathead screwdriver and a Phillips screwdriver.
필요한 것
도구
  1. HP 310-1037 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3개 중 1개 HP 310-1037 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3개 중 2개 HP 310-1037 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 3개 중 3개
    • HP310-1037 Touchsmart PC with a dead hard drive. The hard drive is located behind the stand cover.
    • Lay the PC flat on the front to gain access to the stand cover
    • Remove the single screw that holds the stand cover to the chassis with a flat tip screwdriver
  2. HP 310-1037 Hard Drive Replacement: 2 단계, 이미지 3개 중 1개 HP 310-1037 Hard Drive Replacement: 2 단계, 이미지 3개 중 2개 HP 310-1037 Hard Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the stand cover
    • The hard drive caddy is held in place with 1 Phillips screw
    • Use a #0 Phillips screwdriver to remove that screw
  3. HP 310-1037 Hard Drive Replacement: 3 단계, 이미지 3개 중 1개 HP 310-1037 Hard Drive Replacement: 3 단계, 이미지 3개 중 2개 HP 310-1037 Hard Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Lift the handle on the hard drive caddy
    • and pull it to the backside. This will remove the hard drive caddy from the computer.
    • To remove the hard drive from the caddy, turn it over. There are four Phillips scres that hold the hard drive in place.
  4. HP 310-1037 Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 HP 310-1037 Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Once the four screws are removed, slide the hard drive out of the caddy.
    • Here is the failed drive. It is a Hitachi HDS721010CLA332. Failure with this drive is all to common.
    Where can I Get This Hard Drive? If you can e-mail me alan.becerril14@gmail.com
    Alan Becerril - 답글
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
oldturkey03
회원 가입일: 09/29/10
813,073 평판
안내서 119개를 작성함
Global Fixers Global Fixers 회원
Community
45 회원들
안내서 702개를 작성함
댓글 2개
This one made me laugh - Remove two screws. Pull the drive out. Difficulty: Moderate.
LOL
Justin Coope - 답글
Used this guide to get my failing hard drive, thanks!
AdamG - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 31
전체 시간: 5,033
