주요 콘텐츠로 건너뛰기
HP Chromebook 14-x013dx Speakers Replacement
NHerbert
NHerbert3 다른 기여자
최종 수정일 December 11, 2017
25 분
조정
더 나은 이미지가 필요함
This guide demonstrates the replacement of the Chromebook's speakers. This will require the removal of the front keyboard plate and accessing the laptop's internals. You will need to remove and keep track of thirteen 6mm screws in total.
필요한 것
도구
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
  1. HP Chromebook 14-x013dx Speakers Replacement, Keyboard, Touchpad: 1 단계, 이미지 2개 중 1개 HP Chromebook 14-x013dx Speakers Replacement, Keyboard, Touchpad: 1 단계, 이미지 2개 중 2개
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook 14-x013dx Speakers Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook 14-x013dx Speakers Replacement: 3 단계, 이미지 2개 중 1개 HP Chromebook 14-x013dx Speakers Replacement: 3 단계, 이미지 2개 중 2개
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook 14-x013dx Speakers Replacement: 4 단계, 이미지 2개 중 1개 HP Chromebook 14-x013dx Speakers Replacement: 4 단계, 이미지 2개 중 2개
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook 14-x013dx Speakers Replacement: 5 단계, 이미지 3개 중 1개 HP Chromebook 14-x013dx Speakers Replacement: 5 단계, 이미지 3개 중 2개 HP Chromebook 14-x013dx Speakers Replacement: 5 단계, 이미지 3개 중 3개
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
  6. HP Chromebook 14-x013dx Speakers Replacement, Battery: 6 단계, 이미지 2개 중 1개 HP Chromebook 14-x013dx Speakers Replacement, Battery: 6 단계, 이미지 2개 중 2개
    • Remove the eight 4mm screws holding the battery in place using the Phillips #00 screwdriver.
  7. HP Chromebook 14-x013dx Speakers Replacement: 7 단계, 이미지 2개 중 1개 HP Chromebook 14-x013dx Speakers Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the ribbon cable that runs over the battery by lifting up the plastic latches and pulling the cable away.
  8. HP Chromebook 14-x013dx Speakers Replacement: 8 단계, 이미지 2개 중 1개 HP Chromebook 14-x013dx Speakers Replacement: 8 단계, 이미지 2개 중 2개
    • Unhook the battery's power connector from the motherboard.
  9. HP Chromebook 14-x013dx Speakers Replacement: 9 단계, 이미지 1개 중 1개
    • Lift the battery out of the laptop case.
  10. HP Chromebook 14-x013dx Speakers Replacement, Speakers: 10 단계, 이미지 2개 중 1개 HP Chromebook 14-x013dx Speakers Replacement, Speakers: 10 단계, 이미지 2개 중 2개
    • Unplug Speaker from motherboard.
  11. HP Chromebook 14-x013dx Speakers Replacement: 11 단계, 이미지 2개 중 1개 HP Chromebook 14-x013dx Speakers Replacement: 11 단계, 이미지 2개 중 2개
    • Pull the left and right speaker out carefully.
    • The corners of the the speakers will be held in place by tape, and may require a bit of force.
  12. HP Chromebook 14-x013dx Speakers Replacement: 12 단계, 이미지 2개 중 1개 HP Chromebook 14-x013dx Speakers Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the black tape holding the wire to the laptop casing.
    • Remove the wires from the three hooks on the case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
NHerbert
회원 가입일: 09/28/17
602 평판
안내서 5개를 작성함
USF Tampa, Team S3-G6, Nance Fall 2017 USF Tampa, Team S3-G6, Nance Fall 2017 회원
USFT-NANCE-F17S3G6
4 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 20
전체 시간: 283
