주요 콘텐츠로 건너뛰기
HP Compaq 2510p Power/audio bar Replacement
Derek Kohansky
Derek Kohansky2 다른 기여자
최종 수정일 December 26, 2016
10 분
조정
잘못된 도구
This guide will show step-by-step instruction depicting the replacement of your laptops power/audio bar.
필요한 것
도구
  1. HP Compaq 2510p Power/audio bar Replacement, Power/audio bar: 1 단계, 이미지 1개 중 1개
    • Locate the 4 screws in the four corners of the laptop screen.
    • The screws may be hidden underneath a small rubber pad.
    • Be sure to ground yourself and tools before working near electronics.
  2. HP Compaq 2510p Power/audio bar Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Flathead screwdriver to remove the 4 rubber covers over the 4 screws referenced in step 1.
  3. HP Compaq 2510p Power/audio bar Replacement: 3 단계, 이미지 1개 중 1개
    • Once the rubber has been removed a screw will be revealed. Remove each of the four screws with your Philips head screwdriver.
  4. HP Compaq 2510p Power/audio bar Replacement: 4 단계, 이미지 1개 중 1개
    • Insert your spudger along the top of the screen, separating the plastic cover and the screen
  5. HP Compaq 2510p Power/audio bar Replacement: 5 단계, 이미지 1개 중 1개
    • Continue running your Flathead along the top of the screen until the top is completely separated.
  6. HP Compaq 2510p Power/audio bar Replacement: 6 단계, 이미지 2개 중 1개 HP Compaq 2510p Power/audio bar Replacement: 6 단계, 이미지 2개 중 2개
    • Pull the plastic covering of the screen towards the keyboard, exposing the inner workings of the screen.
  7. HP Compaq 2510p Power/audio bar Replacement: 7 단계, 이미지 1개 중 1개
    • Locate the hinges at the bottom left, and right of the screen
  8. HP Compaq 2510p Power/audio bar Replacement: 8 단계, 이미지 2개 중 1개 HP Compaq 2510p Power/audio bar Replacement: 8 단계, 이미지 2개 중 2개
    • Separate the Power/Audio bar from the hinge by gently pulling.
  9. HP Compaq 2510p Power/audio bar Replacement: 9 단계, 이미지 1개 중 1개
    • Flip the Power/Audio bar over exposing the ribbon wire and its connection to the Power/Audio bar.
  10. HP Compaq 2510p Power/audio bar Replacement: 10 단계, 이미지 1개 중 1개
    • Separate the ribbon wire by gently pulling the wire from its socket.
    • The wire will be separated and the bar is free.
    • Be gentle as you pull.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Derek Kohansky
회원 가입일: 10/26/16
297 평판
안내서 2개를 작성함
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 UMass Dartmouth, Team 3-8, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S3G8
3 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 420
