주요 콘텐츠로 건너뛰기
HP Compaq Presario CQ50/ Warrior power button board Replacement
仙石たった一つの間違い
仙石たった一つの間違い2 다른 기여자
최종 수정일 July 26, 2024
35 초
조정
문법 검토
헷갈리는 텍스트
더 많은 이미지가 필요함
커뮤니티-기여 안내서
세부 사항 누락
if your laptop isn't turning on when plugged in this might be the case
secondly remove the screws in the battery compartment labelled with a keyboard icon
and then the top 2 and middle screws in the battery compartment
thirdly you will want to remove the screws from the top corners of the laptop
then on the topside of the laptop and the display open to reveal the keyboard then the black border of the keyboard slides up and releases is it doesn't check if you have missed any screws after that gently release the ribbon cable from the socket
forth, unscrew the 2 screws holding the warrior board in then change it with your new one and screw it back in, do everything in reverse to reassemble
필요한 것
부품
도구
더보기...
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
    • First remove the battery from the laptop via sliding the release catches.
결론
To reassemble your device, follow these instructions in reverse order. it is also possible dur in reassemble to snap the ribbon cable on the keyboard and power board
작성자
2다른 기여자 명과 함께
仙石たった一つの間違い
회원 가입일: 02/11/24
76 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 37
