주요 콘텐츠로 건너뛰기
HP Compaq Presario V3000 Hard Disk Drive Replacement
Ricky Jaimez
Ricky Jaimez4 다른 기여자
최종 수정일 November 16, 2022
30 분
조정
Removing the hard drive is required when the drive will no longer boot or when you want to upgrade to a larger capacity drive. This task can seem difficult, but is not as bad as you may think! Using a magnetic project mat to hold and label the screws will come in handy during this replacement.
CAUTION: Always unplug the device from the power source or wall outlet before beginning any replacement work.
필요한 것
수리 키트
이 키트는 이 안내서를 완료하는데 필요한 모든 부품과 도구를 포함하고 있습니다.
부품
도구
더보기...
  1. HP Compaq Presario V3000 Hard Disk Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the laptop is powered OFF. Gently turn the laptop over and place it on a flat surface.
    • The battery may be warm or even HOT to the touch.
    • Locate the battery EJECT latch.
  2. HP Compaq Presario V3000 Hard Disk Drive Replacement: 2 단계, 이미지 2개 중 1개 HP Compaq Presario V3000 Hard Disk Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Grab the laptop firmly on the side and using your thumb, press the eject latch towards the OUTER edge of the device.
    • The battery will be lifted out of the laptop slightly as you press the latch over as far as it will go.
    • When replacing the battery, you DO NOT need to adjust the latch. Once the battery is replaced, snap it into place and the latch will return to normal.
  3. HP Compaq Presario V3000 Hard Disk Drive Replacement: 3 단계, 이미지 2개 중 1개 HP Compaq Presario V3000 Hard Disk Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Pull the battery up and towards you to remove it from the laptop chassis.
    • Once the battery is out, you will be able to check the battery label for the replacement part number.
    • The part number is needed when purchasing a new battery.
  4. HP Compaq Presario V3000 Hard Disk Drive Replacement, Hard Disk Drive: 4 단계, 이미지 3개 중 1개 HP Compaq Presario V3000 Hard Disk Drive Replacement, Hard Disk Drive: 4 단계, 이미지 3개 중 2개 HP Compaq Presario V3000 Hard Disk Drive Replacement, Hard Disk Drive: 4 단계, 이미지 3개 중 3개
    • Remove the two Phillips #0, 2.0×5.0 mm hard drive access cover screws. Do not remove them fully. The screws will stay in place on the cover plate.
    • Lift the access cover off and place it to the side out of your way.
  5. HP Compaq Presario V3000 Hard Disk Drive Replacement: 5 단계, 이미지 3개 중 1개 HP Compaq Presario V3000 Hard Disk Drive Replacement: 5 단계, 이미지 3개 중 2개 HP Compaq Presario V3000 Hard Disk Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the two Philips #0 2.5X5.0 mm screws and set them aside.
    • Pull the silver tab back and up to remove the hard drive from the laptop.
  6. HP Compaq Presario V3000 Hard Disk Drive Replacement: 6 단계, 이미지 2개 중 1개 HP Compaq Presario V3000 Hard Disk Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the hard drive up from the laptop. Be careful not to left it all the way.
    • Gently pull the hard drive away from the edge in the direction of the arrow.
    • There are two plastic clips on the hard drive case that insert into the laptop that may break if you lift the hard drive up too far and too fast.
  7. HP Compaq Presario V3000 Hard Disk Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Check the hard drive connections inside the laptop casing. Make sure that they are clean from dust or debris and are straight.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Ricky Jaimez
회원 가입일: 07/20/16
369 평판
안내서 2개를 작성함
University of Memphis, Team 1-4, Kim SU 2016 University of Memphis, Team 1-4, Kim SU 2016 회원
UM-KIM-SU16S1G4
3 회원들
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 17
지난 30일: 34
전체 시간: 6,315
