주요 콘텐츠로 건너뛰기
HP Compaq Presario V5303NR RAM Stick Replacement
필요한 것
  1. HP Compaq Presario V5303NR RAM Stick Replacement, RAM Stick: 1 단계, 이미지 1/3 HP Compaq Presario V5303NR RAM Stick Replacement, RAM Stick: 1 단계, 이미지 2/3 HP Compaq Presario V5303NR RAM Stick Replacement, RAM Stick: 1 단계, 이미지 3/3
    • Turn laptop bottom-side up.
    • Push the battery latch to the left position to unlock the battery.
    • Lift the battery out of its socket.
    • Failure to unplug the computer and remove the battery can result in electrical discharges on contact with the computer's components. This can damage the computer or even hurt the user.
  2. HP Compaq Presario V5303NR RAM Stick Replacement: 2 단계, 이미지 1/2 HP Compaq Presario V5303NR RAM Stick Replacement: 2 단계, 이미지 2/2
    • Use the Phillips #0 Screwdriver to remove the 2 5mm screws.
  3. HP Compaq Presario V5303NR RAM Stick Replacement: 3 단계, 이미지 1/1
    • Remove the plastic cover panel.
  4. HP Compaq Presario V5303NR RAM Stick Replacement: 4 단계, 이미지 1/2 HP Compaq Presario V5303NR RAM Stick Replacement: 4 단계, 이미지 2/2
    • Remove the circular, black piece of plastic shown in the picture by pulling it away from the air vent.
    • Use the Phillips #00 screwdriver to loosen, but not remove, the two 4mm screws shown in the picture.
  5. HP Compaq Presario V5303NR RAM Stick Replacement: 5 단계, 이미지 1/1
    • Lift open the metal access hatch.
  6. HP Compaq Presario V5303NR RAM Stick Replacement: 6 단계, 이미지 1/2 HP Compaq Presario V5303NR RAM Stick Replacement: 6 단계, 이미지 2/2
    • Pull the highlighted latches away from the sides of the RAM Stick to unlock it.
  7. HP Compaq Presario V5303NR RAM Stick Replacement: 7 단계, 이미지 1/1
    • Pull the RAM Stick toward the metal cover's hinge to unplug the RAM stick.
    • Be gentle when removing or installing the RAM. If it breaks, it could damage the adapter that the RAM plugs into.
  8. HP Compaq Presario V5303NR RAM Stick Replacement: 8 단계, 이미지 1/1
    • Carefully remove the unplugged RAM stick through the access hatch.
결론
Chris Obesky
회원 가입일: 03/16/18
617 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S4-G3, Covino Spring 2018 UMass Dartmouth, Team S4-G3, Covino Spring 2018 회원
UMASSD-COVINO-S18S4G3
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 285
