주요 콘텐츠로 건너뛰기
HP Compaq nc6400 RAM Replacement
Luis Vazquez
Luis Vazquez7 다른 기여자
최종 수정일 July 15, 2014
15 - 30 분
조정
RAM stands for Random Access Memory. This memory allows your computer to access recently used data more quickly. This guide will take you through the process of replacing the RAM in an HP Compaq nc6400 Laptop. You will need the correct replacement or compatible RAM for your laptop to complete the installation.
필요한 것
도구
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
더보기...
  1. HP Compaq nc6400 RAM Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off and unplug laptop.
  2. HP Compaq nc6400 RAM Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
  3. HP Compaq nc6400 RAM Replacement: 3 단계, 이미지 1개 중 1개
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
  4. HP Compaq nc6400 RAM Replacement: 4 단계, 이미지 1개 중 1개
    • Once both the battery locks are unlocked, slide the battery out to remove.
  5. HP Compaq nc6400 RAM Replacement, RAM: 5 단계, 이미지 2개 중 1개 HP Compaq nc6400 RAM Replacement, RAM: 5 단계, 이미지 2개 중 2개
    • Remove the 1.2 Philips #1 screw holding down the RAM cover to the body.
  6. HP Compaq nc6400 RAM Replacement: 6 단계, 이미지 1개 중 1개
    • Once the screw is removed, use a spudger to pry open the case covering the RAM chip.
  7. HP Compaq nc6400 RAM Replacement: 7 단계, 이미지 2개 중 1개 HP Compaq nc6400 RAM Replacement: 7 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pull back the white clip holding the RAM chip in place.
    • Once the plastic opening tool has disengaged the clip from the RAM chip, keep the plastic opening tool locked into place.
  8. HP Compaq nc6400 RAM Replacement: 8 단계, 이미지 1개 중 1개
    • With a second plastic opening tool,repeat the above process
    • After both plastic opening tools have been locked in place, the RAM chip should pop out about 1/4 of a inch.
  9. HP Compaq nc6400 RAM Replacement: 9 단계, 이미지 2개 중 1개 HP Compaq nc6400 RAM Replacement: 9 단계, 이미지 2개 중 2개
    • The RAM chip is susceptible to static electricity. Before grabbing the RAM chip, make sure you have discharged the electricity from your hands by touching a metal surface other than your computer.
    • Grab the RAM chip with your thumb and index finger
    • Carefully pull the RAM chip out
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Luis Vazquez
회원 가입일: 09/24/13
401 평판
안내서 2개를 작성함
Cal Poly, Team 14-6, Forte Fall 2013 Cal Poly, Team 14-6, Forte Fall 2013 회원
CPSU-FORTE-F13S14G6
5 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 24
전체 시간: 4,441
