주요 콘텐츠로 건너뛰기
HP EliteBook 1040 G4 Coin Cell Battery  Replacement
SW Reeves
SW Reeves2 다른 기여자
최종 수정일 December 15, 2023
10 - 20 분
조정
Use this guide to replace the coin cell battery on the HP Elitebook 1040 G4. The coin cell battery is essential in laptops to retain certain system settings, such as date and time, while the device is powered off. If you are experiencing problems regarding the time settings or other internal system settings, you may need to replace the coin cell battery.
To complete this guide, you will need a T5 Torx head screwdriver and a Phillips #1 and #00 screwdriver.
Before beginning, be sure to completely power off and unplug your computer.
필요한 것
도구
더보기...
  1. HP EliteBook 1040 G4 Coin Cell Battery  Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  2. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: 2 단계, 이미지 2개 중 1개 HP EliteBook 1040 G4 Coin Cell Battery  Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the back cover up and off the device.
  3. HP EliteBook 1040 G4 Coin Cell Battery  Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
  4. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: 4 단계, 이미지 2개 중 1개 HP EliteBook 1040 G4 Coin Cell Battery  Replacement: 4 단계, 이미지 2개 중 2개
    • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
  5. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: 5 단계, 이미지 2개 중 1개 HP EliteBook 1040 G4 Coin Cell Battery  Replacement: 5 단계, 이미지 2개 중 2개
    • Lift and remove the battery from the device.
  6. HP EliteBook 1040 G4 Coin Cell Battery  Replacement, Coin Cell Battery: 6 단계, 이미지 1개 중 1개
    • Carefully disconnect the pin connector from the right side of the speaker assembly.
  7. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: 7 단계, 이미지 2개 중 1개 HP EliteBook 1040 G4 Coin Cell Battery  Replacement: 7 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove the two 6 mm black screws securing the speakers to the device.
    • Lift the speakers up and out.
  8. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: 8 단계, 이미지 1개 중 1개
    • Carefully disconnect the coin cell battery cable located under the motherboard.
  9. HP EliteBook 1040 G4 Coin Cell Battery  Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the coin cell battery.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 23
전체 시간: 699
