주요 콘텐츠로 건너뛰기
HP EliteBook 745 G4 Battery Replacement
Max Kletskov
Max Kletskov다른 한 명의 기여자
최종 수정일 September 19, 2024
5 - 10 분
조정
How to replace the battery of a HP EliteBook 745 G4 laptop. The images and information in this guide were taken from this computer's service manual.
필요한 것
부품
도구
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
더보기...
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
    • Turn the computer upside down on a flat surface.
  1. HP EliteBook 745 G4 Battery Replacement, Remove the rubber plugs: 2 단계, 이미지 1개 중 1개
    • Remove the 10 rubber plugs from the bottom cover.
    • Remove the SD card blank from the bottom cover.
  2. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: 3 단계, 이미지 2개 중 1개 HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: 3 단계, 이미지 2개 중 2개
    • Remove the 10 Phillips PM2.5x5.0 screws in the following order.
    • After you remove the PM2.5×5.0 screws, remove the PM2.0×7.0 screw.
  3. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover: 4 단계, 이미지 1개 중 1개
    • Pry up on the top (near the display hinge) of the bottom cover to disengage it from the computer. Consider using a spudger.
  4. HP EliteBook 745 G4 Battery Replacement, Remove the battery: 5 단계, 이미지 1개 중 1개
    • Loosen the two captive screws and remove the battery from the computer
결론
To replace the battery & reassemble your device, follow these instructions in reverse order.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Max Kletskov
회원 가입일: 04/22/20
40,850 평판
안내서 16개를 작성함
The Home Depot The Home Depot 회원
Community
18,021 회원들
안내서 140개를 작성함
댓글 2개
you forgot to put the instructions for after the battery is installed when you boot it up You’ll get non-HP battery detected asking you to press enter on every boot. How is this problem fixed?
Richard B - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 41
전체 시간: 1,676
