HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement
Use this guide to replace the heat sink and fan of your HP EliteBook 840 Aero G8. The heat sink and fan need to be replaced if your device is overheating and not performing properly. Be sure to remove the battery before removing the heat sink and fan, as potential for electric shock is present.
Use a JIS #0 screwdriver to unscrew the three 6.73 mm case retention screws.
Use a JIS #0 screwdriver to unscrew and remove the two 8.76 mm screws.
이 단계에 사용된 도구:Halberd Spudger$2.99
Use the Halberd Spudger to remove the cable running along the bottom of the battery
