주요 콘텐츠로 건너뛰기
HP EliteBook x360 1030 G3 Battery Replacement
필요한 것
  1. HP EliteBook x360 1030 G3 Battery Replacement, Bottom Cover: 1 단계, 이미지 1개 중 1개
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Battery Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Remove the five 3.7 mm screws that are holding the battery in place using a Phillips #00 screwdriver.
    • Be sure to keep the screws organized because they will be reused for the next battery installation.
  4. HP EliteBook x360 1030 G3 Battery Replacement: 4 단계, 이미지 2개 중 1개 HP EliteBook x360 1030 G3 Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully pull the white plastic battery connector towards you until it is removed from the port.
    • Be sure not to pull using the wires; doing so may cause damage.
    Connector to the left may be stuck to the battery a little. Don’t worry just be careful.
    Leighton Doswell - 답글
  5. HP EliteBook x360 1030 G3 Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Gently lift the battery out of its place.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Pablo Arriola
회원 가입일: 04/22/19
528 평판
안내서 3개를 작성함
Cal Poly, Team S2-G9, Maness Spring 2019 Cal Poly, Team S2-G9, Maness Spring 2019 회원
CPSU-MANESS-S19S2G9
4 회원들
안내서 16개를 작성함
5 Guide Comments
Thanks, it is very useful.
Mohamed Wafi Aljunaedi - 답글
Looks easy and do you know if the pc can work without battery, only with charger?
Sam Uel - 답글
Thank you. very useful.
mustapha ELABED - 답글
Very simple and precise with good warnings too
Roland Appiah - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 31
지난 30일: 171
전체 시간: 13,349
