주요 콘텐츠로 건너뛰기
HP EliteBook x360 1030 G3 Battery Replacement
Pablo Arriola
Pablo Arriola5 다른 기여자
최종 수정일 December 9, 2023
20 분
조정
추천 학생 안내서
If you are having power issues with this device, replacing the battery may be the solution. This guide will show you how to do so.
However, you should check through the troubleshooting page before proceeding, in case a simpler fix resolves the problem.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
필요한 것
수리 키트
이 키트는 이 안내서를 완료하는데 필요한 모든 부품과 도구를 포함하고 있습니다.
부품
도구
더보기...
  1. HP EliteBook x360 1030 G3 Battery Replacement, Bottom Cover: 1 단계, 이미지 1개 중 1개
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Battery Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Remove the five 3.7 mm screws that are holding the battery in place using a Phillips #00 screwdriver.
    • Be sure to keep the screws organized because they will be reused for the next battery installation.
  4. HP EliteBook x360 1030 G3 Battery Replacement: 4 단계, 이미지 2개 중 1개 HP EliteBook x360 1030 G3 Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully pull the white plastic battery connector towards you until it is removed from the port.
    • Be sure not to pull using the wires; doing so may cause damage.
    Connector to the left may be stuck to the battery a little. Don’t worry just be careful.
    Leighton Doswell - 답글
  5. HP EliteBook x360 1030 G3 Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Gently lift the battery out of its place.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Pablo Arriola
회원 가입일: 04/22/19
528 평판
안내서 3개를 작성함
Cal Poly, Team S2-G9, Maness Spring 2019 Cal Poly, Team S2-G9, Maness Spring 2019 회원
CPSU-MANESS-S19S2G9
4 회원들
안내서 16개를 작성함
댓글 5개
Thanks, it is very useful.
Mohamed Wafi Aljunaedi - 답글
Looks easy and do you know if the pc can work without battery, only with charger?
Sam Uel - 답글
Thank you. very useful.
mustapha ELABED - 답글
Very simple and precise with good warnings too
Roland Appiah - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 52
지난 30일: 176
전체 시간: 13,318
