주요 콘텐츠로 건너뛰기
HP EliteBook x360 830 G7 Battery Replacement
Emily Kaplan
Emily Kaplan6 다른 기여자
최종 수정일 June 24, 2024
5 분
쉬움
This guide will help you remove the battery from your HP EliteBook x360 830 G7 laptop. If the battery of your HP EliteBook x360 830 G7 is draining fast recently, it is probably dying and needs to be replaced.
Batteries are important components of laptops, and without a functional battery your laptop might not perform in the desired manner. Batteries have a limited lifecycle, and after several charge cycles, they might start to drain quicker than usual. If this is happening with you, you might want to start by calibrating the battery. If the problem persists, you most likely need to replace the battery.
This guide will teach you how to replace your HP EliteBook x360 830 G7 battery safely and effectively. Make sure to power down your device before you start.
필요한 것
부품
도구
  • T5 Torx Screwdriver
    T5 Torx Screwdriver
  • JIS #1
  • Spudger
    Spudger
더보기...
  1. HP EliteBook x360 830 G7 Battery Replacement, Remove the backplate: 1 단계, 이미지 3개 중 1개 HP EliteBook x360 830 G7 Battery Replacement, Remove the backplate: 1 단계, 이미지 3개 중 2개 HP EliteBook x360 830 G7 Battery Replacement, Remove the backplate: 1 단계, 이미지 3개 중 3개
    • Turn the computer over so that the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7 Battery Replacement, Disconnect the bundled cable connector: 2 단계, 이미지 1개 중 1개
    • Use a nylon spudger to gently disconnect the battery's bundled cable connector from the motherboard.
    • This bundled cable connector has a tab on each side. Insert the spudger between these tabs and the motherboard's battery connector port and gently push the battery connector out and away from the connector.
  3. HP EliteBook x360 830 G7 Battery Replacement, Peel the copper foil tape: 3 단계, 이미지 2개 중 1개 HP EliteBook x360 830 G7 Battery Replacement, Peel the copper foil tape: 3 단계, 이미지 2개 중 2개
    • Peel back both sides of the copper foil tape connected to the battery.
  4. HP EliteBook x360 830 G7 Battery Replacement, Remove the screws: 4 단계, 이미지 2개 중 1개 HP EliteBook x360 830 G7 Battery Replacement, Remove the screws: 4 단계, 이미지 2개 중 2개
    • Use a JIS #1 screwdriver to remove the four 4 mm screws that secure the battery.
  5. HP EliteBook x360 830 G7 Battery Replacement, Remove the battery: 5 단계, 이미지 3개 중 1개 HP EliteBook x360 830 G7 Battery Replacement, Remove the battery: 5 단계, 이미지 3개 중 2개 HP EliteBook x360 830 G7 Battery Replacement, Remove the battery: 5 단계, 이미지 3개 중 3개
    • Remove the battery from the laptop.
결론
작성자
6다른 기여자 명과 함께
Emily Kaplan
회원 가입일: 03/21/22
217 평판
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 26
지난 30일: 67
전체 시간: 1,237
