주요 콘텐츠로 건너뛰기
HP Elitebook 8460p Cooling Fan Replacement
Garrett Anderson
Garrett Anderson2 다른 기여자
최종 수정일 March 22, 2021
20 분
조정
Use this guide to clean and replace the internal CPU fan and/or heat sink on the HP Elitebook 8460p if it is failing, broken, or if your device is excessively overheating. Signs that the fan has failed, or is failing, can be spotted if the computer frequently shuts down and restarts and displays a warning about overheating and if you do not hear the fan run when the computer initially starts up.
Heat can damage the internal components of the laptop easily if it is not properly controlled. If you are having problems with the operation of the fan, attempt to fix the problem as soon as possible and avoid using the computer as much as possible before fixing the problem.
When opening the laptop up to repair, replace, or clean the fan, make sure to ground yourself with an ESD strap to prevent electrostatic discharges from damaging sensitive components in the laptop such as the motherboard or the processor.
To complete this guide, you will need an ESD strap and a Phillips #0 screw driver.
필요한 것
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. HP Elitebook 8460p Cooling Fan Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Cooling Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Cooling Fan Replacement, Back Panel: 3 단계, 이미지 1개 중 1개
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Cooling Fan Replacement: 4 단계, 이미지 1개 중 1개
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Cooling Fan Replacement, CPU Cooling Fan: 5 단계, 이미지 2개 중 1개 HP Elitebook 8460p Cooling Fan Replacement, CPU Cooling Fan: 5 단계, 이미지 2개 중 2개
    • Attach an ESD strap to your wrist and to a ground.
    • Using a Phillips #0 bit, unscrew the two screws on opposite corners of the fan.
  6. HP Elitebook 8460p Cooling Fan Replacement: 6 단계, 이미지 2개 중 1개 HP Elitebook 8460p Cooling Fan Replacement: 6 단계, 이미지 2개 중 2개
    • Pull the fan straight up and to the side slightly.
  7. HP Elitebook 8460p Cooling Fan Replacement: 7 단계, 이미지 2개 중 1개 HP Elitebook 8460p Cooling Fan Replacement: 7 단계, 이미지 2개 중 2개
    • Disconnect the small electrical connector. Pry the edge up with your finger nails or using a small plastic pry tool.
  8. HP Elitebook 8460p Cooling Fan Replacement: 8 단계, 이미지 1개 중 1개
    • Using a Phillips #0 bit, unscrew the six screws on the heat sink.
  9. HP Elitebook 8460p Cooling Fan Replacement: 9 단계, 이미지 2개 중 1개 HP Elitebook 8460p Cooling Fan Replacement: 9 단계, 이미지 2개 중 2개
    • Pry the inside edge up, pulling the entire assembly to the inside of the laptop, exposing the processor and graphics processor
    • Clean and replace the thermal paste on the processor if you have any thermal paste.
  10. HP Elitebook 8460p Cooling Fan Replacement: 10 단계, 이미지 1개 중 1개
    • Blow compressed air through the vent from the outside and through the heat sink.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Garrett Anderson
회원 가입일: 09/16/19
2,250 평판
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 53
전체 시간: 4,847
