주요 콘텐츠로 건너뛰기
HP Elitebook 8460p Hard Drive Replacement
Garrett Anderson
Garrett Anderson2 다른 기여자
최종 수정일 March 22, 2022
20 분
쉬움
Use this guide if the hard drive in the HP Elitebook 8460p failed or you are looking to upgrade your hard drive with either a new spinning hard drive or a solid state hard drive. The hard drive is where all the data on your laptop is stored - including the Operating System. Before you remove the hard drive, it is strongly recommended to create a backup of all your data.
Most replacement hard drives should come with further instructions or a software tool to back up all the data on your current hard drive and transfer it to the new hard drive before installing the new hard drive.
Before opening the laptop up to replace the hard drive, ground yourself with an ESD strap to prevent electrostatic discharges from damaging or ruining other sensitive electrical components in the laptop.
To complete this guide, you will need a Phillips screw driver #0, an ESD grounding strap, and a replacement SATA hard drive in a 2.5 form factor.
필요한 것
수리 키트
이 키트는 이 안내서를 완료하는데 필요한 모든 부품과 도구를 포함하고 있습니다.
부품
도구
더보기...
  1. HP Elitebook 8460p Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Hard Drive Replacement, Back Panel: 3 단계, 이미지 1개 중 1개
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Hard Drive Replacement, Hard Drive: 5 단계, 이미지 2개 중 1개 HP Elitebook 8460p Hard Drive Replacement, Hard Drive: 5 단계, 이미지 2개 중 2개
    • Attach an ESD strap to your wrist and to a ground.
    • Pull the tab with the small engraved arrow up and towards the inside of the laptop.
  6. HP Elitebook 8460p Hard Drive Replacement: 6 단계, 이미지 2개 중 1개 HP Elitebook 8460p Hard Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Using a Phillips #0 bit, unscrew the three screws that hold the hard drive assembly in place.
  7. HP Elitebook 8460p Hard Drive Replacement: 7 단계, 이미지 2개 중 1개 HP Elitebook 8460p Hard Drive Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the silver metal cover by pulling straight up on the black tab.
  8. HP Elitebook 8460p Hard Drive Replacement: 8 단계, 이미지 1개 중 1개
    • Disconnect the hard drive by pulling the drive straight out to the left.
    • If replacing the hard drive, seat the new hard drive firmly in the connector.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Garrett Anderson
회원 가입일: 09/16/19
2,250 평판
안내서 10개를 작성함
댓글 4개
Thanks! This made hard drive replacement on Elitebook VERY Easy!
Patrick Murphy - 답글
Awesome! So glad that it was able to help you out and keep your Elitebook running. Have a wonderful day!
Garrett Anderson -
Now it won't see the new HD to install to. W10 says the drive can't be used for booting and to enable it in BIOS.
Can't find where to enable it, however.
Rich Frueh - 답글
Meh. Took out battery, let sit for a while. Hit power a few times, plugged back in, and presto!
Not my favorite HP laptop.
Rich Frueh -
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 88
전체 시간: 6,833
