주요 콘텐츠로 건너뛰기
HP Elitebook Folio 9470m Trackpad Replacement
Kenneth Bowers
Kenneth Bowers5 다른 기여자
최종 수정일 December 15, 2023
30 분
조정
Use this guide to replace your HP Elitebook Folio 9470m Trackpad
If your laptop no longer is responsive to movements on the trackpad or does not function properly, your trackpad is likely faulty and may need replacement. There are no special skills involved in the replacement if the trackpad.
Before using this guide, make sure to review the troubleshooting page to ensure that the trackpad doesn't have any driver issues or other issues.
Make sure to power off your laptop completely and disconnect from any external power source before beginning the process.
필요한 것
도구
  1. HP Elitebook Folio 9470m Trackpad Replacement, Trackpad: 1 단계, 이미지 1개 중 1개
    • Flip laptop over.
  2. HP Elitebook Folio 9470m Trackpad Replacement: 2 단계, 이미지 1개 중 1개
    • In the center of the laptop slide the black piece back till it turns red indicating it is unlocked and the battery can be removed.
  3. HP Elitebook Folio 9470m Trackpad Replacement: 3 단계, 이미지 2개 중 1개 HP Elitebook Folio 9470m Trackpad Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the 2 Phillips head screws that attach the cover on the left.
  4. HP Elitebook Folio 9470m Trackpad Replacement: 4 단계, 이미지 3개 중 1개 HP Elitebook Folio 9470m Trackpad Replacement: 4 단계, 이미지 3개 중 2개 HP Elitebook Folio 9470m Trackpad Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the 4 Phillips screws holding the hard drive in place
    • Remove by gently prying and pulling up on the tab and out.
  5. HP Elitebook Folio 9470m Trackpad Replacement: 5 단계, 이미지 3개 중 1개 HP Elitebook Folio 9470m Trackpad Replacement: 5 단계, 이미지 3개 중 2개 HP Elitebook Folio 9470m Trackpad Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the 3 Phillips head screws holding the back plate in.
    • Gently pull up and out to remove plate.
  6. HP Elitebook Folio 9470m Trackpad Replacement: 6 단계, 이미지 2개 중 1개 HP Elitebook Folio 9470m Trackpad Replacement: 6 단계, 이미지 2개 중 2개
    • Remove all eighteen screws marked M2x3 and M2x5.
    • Remove the remaining four Phillips head screws.
  7. HP Elitebook Folio 9470m Trackpad Replacement: 7 단계, 이미지 2개 중 1개 HP Elitebook Folio 9470m Trackpad Replacement: 7 단계, 이미지 2개 중 2개
    • Slowly pry and lift the frame up while checking for connected wires and ribbons that may be obstructing it.
  8. HP Elitebook Folio 9470m Trackpad Replacement: 8 단계, 이미지 2개 중 1개 HP Elitebook Folio 9470m Trackpad Replacement: 8 단계, 이미지 2개 중 2개
    • Detach ribbon wires by gently lifting the grey flap and pulling them out.
    • Do not pull hard on the wires.
    • Push the track pad from the bottom and it should come right out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Kenneth Bowers
회원 가입일: 04/08/16
1,432 평판
안내서 7개를 작성함
UMass Dartmouth, Team S1-G1, Valliere Fall 2018 UMass Dartmouth, Team S1-G1, Valliere Fall 2018 회원
UMASSD-VALLIERE-F18S1G1
4 회원들
안내서 19개를 작성함
1가이드 댓글
Please make sure the Track Pad is not "turned off:" (HP Folio has a Track Pad on/off feature by double-tap in upper left hand corner)
1) Double tap the upper left corner of the Track Pad by the Amber LED
2a) If the LED is "On" then the Track Pad is "Off"
2b) If the LED is "Off" then the Track Pad is "On"
nemisonic - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 36
전체 시간: 4,068
