주요 콘텐츠로 건너뛰기
HP Envy x360 m6-w103dx Daughterboard Replacement
Patrick d'Anjou
Patrick d'Anjou2 다른 기여자
최종 수정일 December 15, 2021
30 - 45 분
조정
This replacement guide is for the daughterboard of the HP Envy x360 m6-w103dx. The daughterboard contains a USB port and SD card slot.
Make sure the computer is unplugged and powered off before touching any internal parts.
Removing the daughterboard is not dangerous and doesn’t require any special technical skills.
필요한 것
도구
더보기...
  1. HP Envy x360 m6-w103dx Daughterboard Replacement, Keyboard: 1 단계, 이미지 2개 중 1개 HP Envy x360 m6-w103dx Daughterboard Replacement, Keyboard: 1 단계, 이미지 2개 중 2개
    • Before you begin, be sure to power off your laptop.
    • Using an opening pick, remove the 4 rubber feet and 4 screw covers.
  2. HP Envy x360 m6-w103dx Daughterboard Replacement: 2 단계, 이미지 2개 중 1개 HP Envy x360 m6-w103dx Daughterboard Replacement: 2 단계, 이미지 2개 중 2개
    • Unscrew the twelve 6 mm screws from the bottom of the laptop using a Phillips #0 screwdriver.
  3. HP Envy x360 m6-w103dx Daughterboard Replacement: 3 단계, 이미지 3개 중 1개 HP Envy x360 m6-w103dx Daughterboard Replacement: 3 단계, 이미지 3개 중 2개 HP Envy x360 m6-w103dx Daughterboard Replacement: 3 단계, 이미지 3개 중 3개
    • Open the laptop carefully, with the keyboard face up.
    • Pry around the outside of the keyboard with the plastic opening tool until the keyboard can be lifted slightly.
    • When lifting the keyboard do not pull too hard. There are cables that must be disconnected before the keyboard can be removed.
  4. HP Envy x360 m6-w103dx Daughterboard Replacement: 4 단계, 이미지 3개 중 1개 HP Envy x360 m6-w103dx Daughterboard Replacement: 4 단계, 이미지 3개 중 2개 HP Envy x360 m6-w103dx Daughterboard Replacement: 4 단계, 이미지 3개 중 3개
    • Lift the keyboard until you can see the cables connected to the motherboard.
    • Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
    • Detach the keyboard.
  5. HP Envy x360 m6-w103dx Daughterboard Replacement, Battery: 5 단계, 이미지 3개 중 1개 HP Envy x360 m6-w103dx Daughterboard Replacement, Battery: 5 단계, 이미지 3개 중 2개 HP Envy x360 m6-w103dx Daughterboard Replacement, Battery: 5 단계, 이미지 3개 중 3개
    • Remove the four 6 mm Phillips #0 screws holding the battery in place.
    • The white arrows on the battery point to where each screw is.
  6. HP Envy x360 m6-w103dx Daughterboard Replacement: 6 단계, 이미지 3개 중 1개 HP Envy x360 m6-w103dx Daughterboard Replacement: 6 단계, 이미지 3개 중 2개 HP Envy x360 m6-w103dx Daughterboard Replacement: 6 단계, 이미지 3개 중 3개
    • Unplug the ribbon cable by flipping up the white tabs on the ZIF connectors and gently sliding the ribbon cables out of their sockets.
    • Unplug the battery connector by grasping the small white tabs on either side of the connector and pulling down towards the battery.
  7. HP Envy x360 m6-w103dx Daughterboard Replacement: 7 단계, 이미지 3개 중 1개 HP Envy x360 m6-w103dx Daughterboard Replacement: 7 단계, 이미지 3개 중 2개 HP Envy x360 m6-w103dx Daughterboard Replacement: 7 단계, 이미지 3개 중 3개
    • Lift out the battery.
    • You may need to peel off the ribbon cable and replace it after installing the new battery if your replacement part doesn't have one already adhered.
  8. HP Envy x360 m6-w103dx Daughterboard Replacement, Daughterboard: 8 단계, 이미지 1개 중 1개
    • Unscrew the two screws from the daughterboard using a Phillips #0 screwdriver.
  9. HP Envy x360 m6-w103dx Daughterboard Replacement: 9 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to remove the daughterboard.
결론
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 177
