HP Mini 210 Netbook WWAN Card Replacement
Replacing the WWAN (Wireless Wide Area Network) card is easy and straightforward.
WWAN connectivity allows a user with a netbook and a WWAN card to surf the web, check email, or connect to a virtual private network (VPN) from anywhere within the regional boundaries of cellular service.
The WWAN card in the HP Mini 210 uses a Mini PCIe interface, which is the standard on recent laptops. Please ensure you install an official HP verified WWAN card to prevent running into errors.
필요한 것
Hold the netbook top-side down with the lid closed.
Slide the plastic battery release latches towards the lock symbols.
Install the new WWAN card and then to reassemble your device, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
apakah benda tersebut ada dalam paket penjualan, atau dijual terpisah?
rioarayana - 답글
I wonder sims slot on hp mini and other major brands also. Toshiba ,Acer
