주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Pavilion 14-v062us Screen Replacement
필요한 것
    1. HP Pavilion 14-v062us Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion 14-v062us Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Power laptop off and make sure it is not plugged into charger
      • Push inward towards the center of laptop (it may take a lot of pressure). Battery should release once buttons are completely pushed in
      댓글 쓰기
    2. HP Pavilion 14-v062us Screen Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 14-v062us Screen Replacement: 2 단계, 이미지 2개 중 2개
      • Lift the battery upwards and out from the laptop
      댓글 쓰기
    1. HP Pavilion 14-v062us Screen Replacement, Keyboard: 3 단계, 이미지 3개 중 1개 HP Pavilion 14-v062us Screen Replacement, Keyboard: 3 단계, 이미지 3개 중 2개 HP Pavilion 14-v062us Screen Replacement, Keyboard: 3 단계, 이미지 3개 중 3개
      • Remove rectangular rubber tops with a spudger
      • Remove the two 4.60 mm PH#1 screws located under rectangular rubber tops.
      • Remove plastic edge covering with the blue plastic opening tool.
      • Remove two 4.63 mm PH#1 screws located under plastic edge covering.
      댓글 쓰기
    2. HP Pavilion 14-v062us Screen Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion 14-v062us Screen Replacement: 4 단계, 이미지 2개 중 2개
      • Use Phillips screwdriver #1
      • Remove all nine 7.09 mm PH#1 screw black screws including small rectangular cover.
      • Remove the three 7.14 mm PH#1 screws.
      • Remove the one 7.09 mm PH#1 screw that will be underneath the small rectangular cover
      댓글 쓰기
    3. HP Pavilion 14-v062us Screen Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion 14-v062us Screen Replacement: 5 단계, 이미지 2개 중 2개
      • Remove disc tray
      • Locate screw within computer that is inside of where the disc tray was
      • Using a Phillips #1 screwdriver, unscrew the screw
      • Set laptop down and open laptop so the keyboard is facing you
      댓글 쓰기
    4. HP Pavilion 14-v062us Screen Replacement: 6 단계, 이미지 3개 중 1개 HP Pavilion 14-v062us Screen Replacement: 6 단계, 이미지 3개 중 2개 HP Pavilion 14-v062us Screen Replacement: 6 단계, 이미지 3개 중 3개
      • Using a spudger or plastic opening tool, pry along siding of keyboard, where it connects to the rest of the laptop
      • Pry until you are able to lift entire face and keyboard
      • Only cables should be connecting it underneath
      댓글 쓰기
    5. HP Pavilion 14-v062us Screen Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion 14-v062us Screen Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion 14-v062us Screen Replacement: 7 단계, 이미지 3개 중 3개
      • Disconnect/ unplug cables using plastic opening tool.
      • Separate the keyboard panel from the laptop with your hands.
      • Turn around the laptop and lay it flat.
      댓글 쓰기
    6. HP Pavilion 14-v062us Screen Replacement: 8 단계, 이미지 2개 중 1개 HP Pavilion 14-v062us Screen Replacement: 8 단계, 이미지 2개 중 2개
      • Use a spudger to pry around the first layer of the silver panel until you are able to remove it
      • Only use a metal spudger as a last resort
      댓글 쓰기
    7. HP Pavilion 14-v062us Screen Replacement: 9 단계, 이미지 3개 중 1개 HP Pavilion 14-v062us Screen Replacement: 9 단계, 이미지 3개 중 2개 HP Pavilion 14-v062us Screen Replacement: 9 단계, 이미지 3개 중 3개
      • Using a spudger tool, start prying around the second layer of the silver panel until you are able to remove it
      댓글 쓰기
    1. HP Pavilion 14-v062us Screen Replacement, Screen: 10 단계, 이미지 3개 중 1개 HP Pavilion 14-v062us Screen Replacement, Screen: 10 단계, 이미지 3개 중 2개 HP Pavilion 14-v062us Screen Replacement, Screen: 10 단계, 이미지 3개 중 3개
      • Using the spudger, wedge tool in between screen and laptop
      • Only use a metal spudger as a last resort. A regular black nylon spudger or a plastic opening tool should be used whenever possible
      • Pry open screen with spudger and your hands
      댓글 쓰기
    2. HP Pavilion 14-v062us Screen Replacement: 11 단계, 이미지 3개 중 1개 HP Pavilion 14-v062us Screen Replacement: 11 단계, 이미지 3개 중 2개 HP Pavilion 14-v062us Screen Replacement: 11 단계, 이미지 3개 중 3개
      • Remove the four 2.86 mm JIS#0 screws from each corner of the silver frame that is holding the digitizer.
      댓글 쓰기
    3. HP Pavilion 14-v062us Screen Replacement: 12 단계, 이미지 2개 중 1개 HP Pavilion 14-v062us Screen Replacement: 12 단계, 이미지 2개 중 2개
      • Locate the white and brown wiring that connects to the digitizer and the screen.
      • Cut through the clear part of tape attached to the brown latch and white wiring.
      • Disconnect the wiring, by lifting the brown latch with the blue plastic opening tool and pulling the white wire at the same time.
      • Lift off the digitizer. If you need to replace the digitizer stop here and replace this part.
      • If you need to replace the screen, then continue
      댓글 쓰기
    4. HP Pavilion 14-v062us Screen Replacement: 13 단계, 이미지 1개 중 1개
      • Remove the four 5.66 mm PH#0 from under the keyboard near the hinges.
      댓글 쓰기
    5. HP Pavilion 14-v062us Screen Replacement: 14 단계, 이미지 3개 중 1개 HP Pavilion 14-v062us Screen Replacement: 14 단계, 이미지 3개 중 2개 HP Pavilion 14-v062us Screen Replacement: 14 단계, 이미지 3개 중 3개
      • Wedge spudger in between screen and back of computer
      • Detach screen
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Lorena Esquivel
회원 가입일: 09/27/17
247 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 36
전체 시간: 1,882
