주요 콘텐츠로 건너뛰기
HP Pavilion 15-ab243cl Case Removal
Alexander Bicigo
Alexander Bicigo3 다른 기여자
최종 수정일 May 28, 2018
10 - 30 분
조정
If you need to access internal components on your laptop, it is necessary to remove the case of the laptop. This guide will show you all the steps involved in the removal of the case.
필요한 것
도구
더보기...
  1. HP Pavilion 15-ab243cl Case Removal, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-ab243cl Case Removal, Battery: 1 단계, 이미지 2개 중 2개
    • Slide the battery lock tab toward the center of the battery to the unlock position.
  2. HP Pavilion 15-ab243cl Case Removal: 2 단계, 이미지 3개 중 1개 HP Pavilion 15-ab243cl Case Removal: 2 단계, 이미지 3개 중 2개 HP Pavilion 15-ab243cl Case Removal: 2 단계, 이미지 3개 중 3개
    • Slide the battery release switch to the right until the battery pops out.
  3. HP Pavilion 15-ab243cl Case Removal: 3 단계, 이미지 2개 중 1개 HP Pavilion 15-ab243cl Case Removal: 3 단계, 이미지 2개 중 2개
    • Grabbing the top edge of the battery, rotate it toward you and then lift upward to relieve the battery from its slot.
  4. HP Pavilion 15-ab243cl Case Removal, Laptop Case: 4 단계, 이미지 3개 중 1개 HP Pavilion 15-ab243cl Case Removal, Laptop Case: 4 단계, 이미지 3개 중 2개 HP Pavilion 15-ab243cl Case Removal, Laptop Case: 4 단계, 이미지 3개 중 3개
    • With the battery removed, remove both black plastic covers with a plastic opening tool. Unscrew both 7.5 mm screws from the tabs, using a PH1 screw driver. Using a plastic opening tool, pry off both covers.
  5. HP Pavilion 15-ab243cl Case Removal: 5 단계, 이미지 3개 중 1개 HP Pavilion 15-ab243cl Case Removal: 5 단계, 이미지 3개 중 2개 HP Pavilion 15-ab243cl Case Removal: 5 단계, 이미지 3개 중 3개
    • Remove all 16 of the 3.5 mm screws with a PH1 screwdriver and pry/slide the CD drive out of laptop.
  6. HP Pavilion 15-ab243cl Case Removal: 6 단계, 이미지 2개 중 1개 HP Pavilion 15-ab243cl Case Removal: 6 단계, 이미지 2개 중 2개
    • With the CD drive removed, unscrew the two 2mm silver screws with a PH00.
    • These can strip easily, so take your time removing.
  7. HP Pavilion 15-ab243cl Case Removal: 7 단계, 이미지 3개 중 1개 HP Pavilion 15-ab243cl Case Removal: 7 단계, 이미지 3개 중 2개 HP Pavilion 15-ab243cl Case Removal: 7 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, begin to pry edge of case away from the laptop. Work around the edges until all sides, except back, are open.
  8. HP Pavilion 15-ab243cl Case Removal: 8 단계, 이미지 3개 중 1개 HP Pavilion 15-ab243cl Case Removal: 8 단계, 이미지 3개 중 2개 HP Pavilion 15-ab243cl Case Removal: 8 단계, 이미지 3개 중 3개
    • On the back side of the laptop, where the battery is, there are 12 black plastic clips. Use a plastic opening tool and pry all of these clips, unlatching them from the case.
    • Once clips are free, open the laptop. Rotating the case off, around the hinges, works best to remove the case.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Alexander Bicigo
회원 가입일: 02/14/18
942 평판
안내서 6개를 작성함
USF Tampa, Team S6-G3, Eyestone Spring 2018 USF Tampa, Team S6-G3, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S6G3
3 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 25
전체 시간: 1,272
