주요 콘텐츠로 건너뛰기
HP Pavilion 15-ay041wm Keyboard Replacement
Kristen Gismondi
Kristen Gismondi2 다른 기여자
최종 수정일 July 11, 2024
10 - 20 분
조정
더 나은 소개글
If your HP pavilion 15-ay041wm laptop keyboard is not functioning properly, this guide details how to install a replacement keyboard. Ensure that the laptop is unplugged before starting this repair.
필요한 것
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. HP Pavilion 15-ay041wm Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-ay041wm Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Place the laptop upside down.
  2. HP Pavilion 15-ay041wm Keyboard Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 15-ay041wm Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Find the battery lock latch on the top left corner.
    • Slide the latch to the right position.
  3. HP Pavilion 15-ay041wm Keyboard Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion 15-ay041wm Keyboard Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion 15-ay041wm Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • Find the battery release latch on the top right corner.
    • Slide and hold the latch towards the left to cover the battery icon.
    • Carefully slide the battery outwards.
  4. HP Pavilion 15-ay041wm Keyboard Replacement, Disc Drive: 4 단계, 이미지 1개 중 1개
    • Turn the laptop upside down with the base of the laptop facing you.
    • Remove the grippers positioned at the top right and top left of the laptop to access the two additional screws.
    • Use a 1.5mm Hex screwdriver to remove twelve 10mm screws.
  5. HP Pavilion 15-ay041wm Keyboard Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion 15-ay041wm Keyboard Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion 15-ay041wm Keyboard Replacement: 5 단계, 이미지 3개 중 3개
    • Press the eject button.
    • Hold and carefully slide the disc drive out of the laptop.
  6. HP Pavilion 15-ay041wm Keyboard Replacement, Keyboard: 6 단계, 이미지 3개 중 1개 HP Pavilion 15-ay041wm Keyboard Replacement, Keyboard: 6 단계, 이미지 3개 중 2개 HP Pavilion 15-ay041wm Keyboard Replacement, Keyboard: 6 단계, 이미지 3개 중 3개
    • Using the Jimmy, create a separation between the keyboard and bottom panel.
    • Slide around the body of the panel until the separation is big enough for you to use your fingers.
    • Separate the keyboard and bottom panel.
결론
작성자
2다른 기여자 명과 함께
Kristen Gismondi
회원 가입일: 11/12/14
92,429 평판
안내서 241개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,543개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 33
전체 시간: 808
