주요 콘텐츠로 건너뛰기
HP Pavilion 15-b109wm Keyboard Replacement
David Atunlute
David Atunlute3 다른 기여자
최종 수정일 May 21, 2024
10 - 20 분
조정
This replacement guide will show how to replace the keyboard of an HP Pavilion 15-b109wm. This process will take between 10-20 minutes, if done correctly. Remember to take your time and do the steps correctly and gently to avoid parts breakage.
필요한 것
도구
더보기...
  1. HP Pavilion 15-b109wm Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Power off the device and disconnect from any power source.
  2. HP Pavilion 15-b109wm Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Turn the device upside down and ensure the back of the device is facing you.
  3. HP Pavilion 15-b109wm Keyboard Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion 15-b109wm Keyboard Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion 15-b109wm Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • Push both buttons towards one another simultaneously. The battery slightly pops out.
  4. HP Pavilion 15-b109wm Keyboard Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion 15-b109wm Keyboard Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion 15-b109wm Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    • Pull out the battery from the device's battery slot.
  5. HP Pavilion 15-b109wm Keyboard Replacement, Keyboard: 5 단계, 이미지 2개 중 1개 HP Pavilion 15-b109wm Keyboard Replacement, Keyboard: 5 단계, 이미지 2개 중 2개
    • Use JIS #1 screwdriver to remove the eleven 6 mm screws.
  6. HP Pavilion 15-b109wm Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Locate the two screw holes that allow access to removing the keyboard.
    • There is a keyboard sign beside both keyboard access holes.
  7. HP Pavilion 15-b109wm Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Heavy-Duty Spudger
    • Turn the device onto its side.
    • Using a heavy duty spudger, gently disengage the keyboard.
  8. HP Pavilion 15-b109wm Keyboard Replacement: 8 단계, 이미지 2개 중 1개 HP Pavilion 15-b109wm Keyboard Replacement: 8 단계, 이미지 2개 중 2개
    • Using a plastic opening tool, release the keyboard clips.
  9. HP Pavilion 15-b109wm Keyboard Replacement: 9 단계, 이미지 1개 중 1개
    • Tilt the keyboard to expose the Zero Insertion Force connector to which the keyboard cable is attached.
  10. HP Pavilion 15-b109wm Keyboard Replacement: 10 단계, 이미지 3개 중 1개 HP Pavilion 15-b109wm Keyboard Replacement: 10 단계, 이미지 3개 중 2개 HP Pavilion 15-b109wm Keyboard Replacement: 10 단계, 이미지 3개 중 3개
    • Disconnect the keyboard cable from the motherboard by detaching the Zero Insertion Force connector.
    • To detach the connector, release by lifting the black plastic tab up.
결론
작성자
3다른 기여자 명과 함께
David Atunlute
회원 가입일: 10/30/18
241 평판
안내서 2개를 작성함
UMass Dartmouth, Team S2-G2, Peak Fall 2018 UMass Dartmouth, Team S2-G2, Peak Fall 2018 회원
UMASSD-PEAK-F18S2G2
3 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 16
전체 시간: 547
