주요 콘텐츠로 건너뛰기
HP Pavilion 15-ba003ds Backplate Replacement
Krushnam Badami
Krushnam Badami4 다른 기여자
최종 수정일 June 19, 2020
6 - 10 분
매우 쉬움
학생이 작성 중
This guide will detail how you can get into the HP Pavilion 15-ba003ds by providing you the steps to follow in order to safely remove the back plate from your laptop. This guide may be of use to you should you need to have access to the internal components of your laptop for any repair, replacements, or cleaning of the laptop.
필요한 것
도구
  1. HP Pavilion 15-ba003ds Backplate Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-ba003ds Backplate Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Backplate Replacement, Disc Drive: 2 단계, 이미지 1개 중 1개
    • Remove the two rubber feet next to the battery.
  3. HP Pavilion 15-ba003ds Backplate Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion 15-ba003ds Backplate Replacement: 3 단계, 이미지 2개 중 2개
    • There are twelve 8mm screws in total that need to be unscrewed
    • Using a Phillips #00 screwdriver, unscrew them all including the two screws found underneath the rubber feet.
  4. HP Pavilion 15-ba003ds Backplate Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion 15-ba003ds Backplate Replacement: 4 단계, 이미지 2개 중 2개
    • Once all twelve screws are removed the disc drive can now be gently pulled out by hand.
  5. HP Pavilion 15-ba003ds Backplate Replacement, Backplate: 5 단계, 이미지 3개 중 1개 HP Pavilion 15-ba003ds Backplate Replacement, Backplate: 5 단계, 이미지 3개 중 2개 HP Pavilion 15-ba003ds Backplate Replacement, Backplate: 5 단계, 이미지 3개 중 3개
    • Use a Jimmy to pry off the black backplate.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Krushnam Badami
회원 가입일: 01/14/20
342 평판
안내서 3개를 작성함
York University, Team S1-G9, Woodhouse Winter 2020 York University, Team S1-G9, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G9
3 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 16
전체 시간: 536
