주요 콘텐츠로 건너뛰기
HP Pavilion 15-ba003ds Cooling Fan Replacement
Krushnam Badami
Krushnam Badami2 다른 기여자
최종 수정일 June 19, 2020
15 - 25 분
조정
학생이 작성 중
잘못된 도구
This guide will provide you with the steps you will need to follow in order to replace the cooling fan in your HP Pavilion 15-ba003ds.
This guide will be useful if you find that your laptop struggles to adequately cool your laptop.
필요한 것
도구
  • Jimmy
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
더보기...
  1. HP Pavilion 15-ba003ds Cooling Fan Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-ba003ds Cooling Fan Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Cooling Fan Replacement, Disc Drive: 2 단계, 이미지 1개 중 1개
    • Remove the two rubber feet next to the battery.
  3. HP Pavilion 15-ba003ds Cooling Fan Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion 15-ba003ds Cooling Fan Replacement: 3 단계, 이미지 2개 중 2개
    • There are twelve 8mm screws in total that need to be unscrewed
    • Using a Phillips #00 screwdriver, unscrew them all including the two screws found underneath the rubber feet.
  4. HP Pavilion 15-ba003ds Cooling Fan Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion 15-ba003ds Cooling Fan Replacement: 4 단계, 이미지 2개 중 2개
    • Once all twelve screws are removed the disc drive can now be gently pulled out by hand.
  5. HP Pavilion 15-ba003ds Cooling Fan Replacement, Backplate: 5 단계, 이미지 3개 중 1개 HP Pavilion 15-ba003ds Cooling Fan Replacement, Backplate: 5 단계, 이미지 3개 중 2개 HP Pavilion 15-ba003ds Cooling Fan Replacement, Backplate: 5 단계, 이미지 3개 중 3개
    • Use a Jimmy to pry off the black backplate.
  6. HP Pavilion 15-ba003ds Cooling Fan Replacement, Cooling Fan: 6 단계, 이미지 2개 중 1개 HP Pavilion 15-ba003ds Cooling Fan Replacement, Cooling Fan: 6 단계, 이미지 2개 중 2개
    • Remove three black 6mm Phillips #00 screws.
  7. HP Pavilion 15-ba003ds Cooling Fan Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion 15-ba003ds Cooling Fan Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion 15-ba003ds Cooling Fan Replacement: 7 단계, 이미지 3개 중 3개
    • Unplug the white connector using your fingers or a spudger.
  8. HP Pavilion 15-ba003ds Cooling Fan Replacement: 8 단계, 이미지 3개 중 1개 HP Pavilion 15-ba003ds Cooling Fan Replacement: 8 단계, 이미지 3개 중 2개 HP Pavilion 15-ba003ds Cooling Fan Replacement: 8 단계, 이미지 3개 중 3개
    • Pull out the fan by hand.
결론
작성자
2다른 기여자 명과 함께
Krushnam Badami
회원 가입일: 01/14/20
342 평판
안내서 3개를 작성함
York University, Team S1-G9, Woodhouse Winter 2020 York University, Team S1-G9, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G9
3 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 20
전체 시간: 339
