주요 콘텐츠로 건너뛰기
HP Pavilion 15-cc561st Battery Replacement
필요한 것
  1. HP Pavilion 15-cc561st Battery Replacement, Bottom Cover: 1 단계, 이미지 3개 중 1개 HP Pavilion 15-cc561st Battery Replacement, Bottom Cover: 1 단계, 이미지 3개 중 2개 HP Pavilion 15-cc561st Battery Replacement, Bottom Cover: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Before you begin to remove the bottom cover, shut down the computer. Disconnect all external devices and unplug the AC adapter. Flip the laptop upside down.
    • Use a Phillips #0 screwdriver to remove five screws from the bottom cover:
    • Two 5.6 mm screws
    • Each of these screws are beneath the two rubber feet on the rear side of the laptop (near the display hinges). You do not have to completely remove the rubber feet to remove the screws; simply peel the top of the feet to reveal the screws.
    • Three 5.8 mm screws
    • Throughout this repair, keep track of each screw size and location to avoid damaging your device.
  2. HP Pavilion 15-cc561st Battery Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 15-cc561st Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Insert an opening tool into the space between the display hinges and the bottom cover.
    • Firmly push the opening tool upwards to separate the bottom cover from these areas.
  3. HP Pavilion 15-cc561st Battery Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion 15-cc561st Battery Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion 15-cc561st Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Insert your opening tool and firmly push the tool upwards along the rear edge.
  4. HP Pavilion 15-cc561st Battery Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion 15-cc561st Battery Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion 15-cc561st Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Use the opening tool again on the left and right sides.
    • Start prying at the areas closer to the rear of the laptop (near the display hinges) before moving towards areas that are closer to the front of the laptop (away from the display hinges).
    • Pry a little bit on the left side, then pry a little bit on the right side before prying more on the left side again. Working on both sides in this incremental fashion is easier than completely prying one side before starting the other side.
  5. HP Pavilion 15-cc561st Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the bottom cover upwards to remove it.
  6. HP Pavilion 15-cc561st Battery Replacement, Battery: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the five 5.7 mm screws that secure the battery.
  7. HP Pavilion 15-cc561st Battery Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion 15-cc561st Battery Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion 15-cc561st Battery Replacement: 7 단계, 이미지 3개 중 3개
    • Pull the battery towards the front edge of the laptop to disconnect it from the 8-pin battery connector.
    • Lift the disconnected battery upwards to remove it.
    • Calibrate a newly-installed battery to help your laptop get an accurate battery percentage reading.
결론
작성자
1다른 기여자 명과 함께
Nathan Luu
회원 가입일: 09/26/22
569 평판
안내서 5개를 작성함
CSU Los Angeles, Team 6-4, Adachi Fall 2022 CSU Los Angeles, Team 6-4, Adachi Fall 2022 회원
CSULA-ADACHI-F22S6G4
4 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 66
전체 시간: 1,800
